TomcoPDR
Great size home garage, good build.
very interested in your build. I would like to do the same thing. What is your wall height?
Because I have a 13.5' tall fifth wheel.
Garage looks great.
Have you finished off the inside yet? Why all the CAT6?
The inside ceiling is all sheetrocked and insulated. I used 12 foot sheets of 5/8 sheetrock which was a lot of fun to do by myself. I used fiberglass insulation under where the attic floor is (R42), and I blew in 19" of all Borate cellulose on both sides which settled to about 16". The walls are not done yet. I got sidetracked with some car projects, so I haven't really worked on the garage. I really want to get the radiant floor hooked up before winter and continue with the sheetrock on the walls.
The cat6 is for POE security cameras, network jacks, I ran a couple runs to where the TV is just incase, and I even used the cat 6 to the phone jack. There is a whole 1000 foot spool of cat6 in there. It's overkill, but down the road I didn't want to regret not doing enough.
I have a few more pictures I will post
Really cool build! I enjoy seeing how others deal with the original small garages most houses have.
I see that you have a header already framed in the rear wall. Any reason you haven't put in a rear door?
Luke
Looks awesome. Out of curiosity, why did you remove the existing structure instead of just adding onto it?
