Single pole LED dimmer switch
JohnKal
New York State
Maybe it's just me, but I can't seem to locate a single pole LED toggle dimmer switch. Everything I'm finding is a 3 way, which obviously can be used as a SP dimmer. I just figure a SP would be less expensive. Any and all help will be appreciated
dscheidt
it would be less expensive, but then stores (and manufacturers) would have to keep two different switches in stock. That would raise costs. The extra terminal is a pretty marginal cost compared to the electronics required to dim. Just use the three way switches, and ignore the extra terminal.
J
JohnKal
New York State
When you say led do you mean compatible with led?
Yes, LED compatible
Makes sense.
Thanks guys.
Viper98912
GA
Yup they're all pretty much single and 3 way. Just buy install and get er done :)
