The VISES of Garage Journal
gman007
West Michigan
Can't find any info based on the numbers on this vise.. Any info and what it's current rough value would be estimated at? $450 seems a little steep seeing as it's missing the jaws from what I can tell.
Based on the jaw type alone looks like a Prker. There is a Chas Parker 89 1/2 weight 141 lb , jaws 5 3/8 with pipe jaws (and yes the pipe jaws on this one are missing, but then what is new about missing pipe jaws) but 89 1/2 is supposed to have a swivel base where as this one looks like it has a fixed base :headscrat
Edit
Here is a photo of an 88 from the same Superior series as 89 1/2 and this one looks has in fact a swivel base.
As for price I am in agreement with 454 and Outlaw is way overpriced.
pikapp
South Florida
Rege
That 5170 is terrific. The bullet shaped spindle and matching handle are in amazing condition. I really like the tools the designer took the time to design some style into them also. Combining style and function. Very nice!
Smith3085
Western New York
Just found this today in my barn in a corner under the stair case...actually looking for some further info and maybe a value. Measures 7" open and wide...Heuer rear clamping vise. I think it's pretty cool! Heavy! Seems to be unaltered.
justin.d.richards.9
Edit
Here is a little bit better photo.. you can clearly see where the base has been modified.. It's tempting to message them but I don't think I will bother with it. I did message the person with the $900 Wilton with an offer and they weren't happy. It happens.
Stuart in MN
Minneapolis
I came across a Youtube video of a guy building a vise out of a piece of railroad track, it came out pretty nice. Most of the machining is done on a large horizontal mill. The captions are in Spanish but you can get the gist of what he's doing.
justin.d.richards.9
Here's one with English subs. Different person though. This one kept some of the railroad track look though
gman007
West Michigan
Stuart and Justin
Thank you both for the very interesting videos. It seems the first guy’s ( I am guessing he might be from Spain) setup was a lot more high tech than the oriental fellow but both are definitely very high skilled craftsmen. And both vises turned out very nice.
454ragtop
Carver, MA
Jaw support is broken off, not worth $50. IMO, unless it has parts you need,
454ragtop
Carver, MA
Found these 2 " I Beam " style vises at the flea market today, smaller one has 1" jaws, larger 1-1/2". Don't usually bother with these, very often they're broken where the dynamic lips over the slide. These 2 are fairly tight, good jaw alignment, appear to have seen very little use. So, since they were cheap, I added them to the collection.
va.grouseman
Southern-Central VA.
These are for KMS's info site per request.---Posted these before but didn't have the stats to go with them.
3 Prentiss Shepherds.---Pig feet for reference.---Didn't have a soda or a beer.---Sorry.
And individual pics of each.
First is #60
Opens 2 1/2''
Jaw width, 2''
Weight, 5.5 lbs.
Smooth jaws, no inserts.
va.grouseman
Next is #61
Opens 3 1/4''
Jaw width, 2 1/2''
Weight, 12 lbs.
I think someone removed the base on this one at some time or another and made it a stationary.---Hence the holes in the base.
va.grouseman
Next is #69
Opens 11''
Jaw width, 4 5/8''
Weight, 45 lbs.
dopod
Northern Michigan
Found a wilton 8450 on Craigslist for $100. The dynamic jaw was seized in static, but it was no match for the 100 ton press at work. Previous owners hammered on it and broke the slot on the lead screw trying to free it up. I welded the broken piece back in cleaned everything up and painted. Date code says 1953. This vise should outlast me; I'm excited to put it back to work!
rcrcrc21
Texas
Hello. Bought a Reed vise today. Has “Patent Nov 3 1908” on one side and “424” on the other side. I researched this site and Google and was not able to locate a model 424. It has the swivel rear jaw like other 400 series and it has has 4 inch jaws. Just curious if anyone has any more info on the 424? Thanks.
gman007
West Michigan
RC
424 is a filers vise (fairly rare) and is listed in the vise spread sheet
Weight 59 lb
Jaw 4”
Opening 6 1/2”
Ps
Very nice find :thumbup:
zoomieport
The Mall City
Here is a "Railroad Track Anvil / Vise" I found a while back, it's pretty cool...
Take care!
ZOOM
LesserSon
PA USA
I had posted a Spear & Jackson rip saw I picked up this weekend. Got it home and compare it to another I bought a couple years back, and surprise! Mirror images. Hmmm. Why? For lefties and righties? Or maybe from an era when no one was looking which side of a saw had a stamp or medalion? Any Brits have enough of these to know?
kwoswalt99
Detroit
What type of vise is this?
rusty65
Pekin,IL
RC
Weight 59 lb
Jaw 4”
Opening 6 1/2”
Ps
I believe that’s actually a coach makers vise some one has cut the jaw height down on. I have a 414 1/2 reed which is a fillers model swivel jaw with swivel c534ffc7c0656533366fe8e6106b58e7.jpg
davethorik
Norka, Ohio
Took a little bit of time today to start working on my Prentiss no. 456. Today was focused just on the slide, as I got a tight spot about 1/2 way when putting back together. Cleaning screw and nut yielded no results, filing slide next step.
It looks like the slide of this vise was used as an anvil more than actual vise usage, so there was a fair bit of mushrooming about 6" front the end. However there is a spot on all 3 sides where metal not oxidized, about where the vise body would be with vise closed. So, i think this sat somewhere for a while without being used.
Acetone, rag, scraper, stiff wire brush, and a new Hecho en Mexico Nicholson file made quick work of the job.
Look at the bottom of the slide. Is that typical? It appears to be hand-scraped/flaked flat, like on a precision machine.
View media item 85406
View media item 85407
View media item 85408
View media item 85409
View media item 85410
gman007
West Michigan
Is there an accepted standard in terms of jaw height to distinguish between filers and coach makers vises?
PS
Had a another look at the photo of the 424 and at least to me it does not look it was altered. If it was altered someone did a great job. I also checked the vise spread sheet and there too 424 is listed as filers vise.
G man i think its more about the angle at the tip of the jaws and how close it starts to the jaw faces. For a filers you need that clearance at times. Less so on the pattern makers/coach makers vise.
gman007
West Michigan
Outlaw
Thanks for clarification, this make sense. Incidentally from the posted photos of the 424 the angle seems to be pretty steep.
chrisnazzy
Arizona
I have these saved if they can help clarify Reed's specific terminology for 414 vs. 424 swivel jaws.d35189550ffc344c9520b705e7bd4cce.jpgd03d36de2b4c5c5bc2224b98dffe135e.jpg
neophyte
Pennsylvannia
Any idea what this is?
The anvil horn and covered spindle makes me think Craftsman. The seller says he sees no maker's mark. I'm in Europe.
That could be a Yost 905-AS vise.
Cast steel front and rear jaw, with a formed steel slide.
The currently manufactured versions are made in either Taiwan or China. Older ones might have been made in the USA, but I’m not completely sure.
There’s currently at least one other manufacturer yhat sells the same vise with a different paint job, and maybe others.
This is the vise on the Yost website.
http://www.yostvises.com/products/b...ty-combination-pipe-and-bench-vise-black.html
Imazagi
Austria
My new old York 100
I have a dedicated thread over in Vintage Tools, and just want to add the basic info here for reference.
Found this unnamed vise in the local ads and bought it for €47 shipped:
Even after taking it apart and stripping it, I found no reference to the maker, although it looks a lot like a York, the original Wilton bullet design:
2 coats of primer, some filler, 3 coats of Peugeot red from my mom's 208:
I asked at York.cz, who came back to me first thing Monday morning and confirmed that this is in fact a York 100, made between 1934 and 1956.
All in all a great little vise, although not as smooth as my green FPU in the background, and it only swivels 90 degrees. But I needed a vise for the cabin and will be a great addition to the basic shop there.
So besides the jaw differences, the length of the slide (and resulting added opening) on the coach/pattern makers allows larger work pieces.
