MeanYellowZ
- Joined
- Jan 12, 2010
- Messages
- 22
This is very lengthy and I apologize but appreciate anyone taking the time to read through this stuff and offer advice. Also, this is my first post here. Very active on many other forums, just new to this one.
Alright guys, I need some advice here on a huge project I have found myself in the middle of. First off I want to make a few points:
I am in no mean trying to offend or piss off any of you that own/ work at any construction/ electrical/ plumbing operations. I know that some of my thoughts can/ may go against what puts food on your table/ etc and that is not my intent.
I am in Iowa, so I know some of the specifics may be different than your state but I'm sure some of the basics will still apply.
I am relatively good at some areas of automotive work/ wiring, etc, but I am an absolute MESS at anything home related. Building a birdhouse may very well be over my personal abilities
Lastly, I have nowhere near the amount of money needed to make all of the work happen that needs done, so I have to pick and choose where money MUST be spent and get by on the stuff I can get by on.
That said, what I have going on here is a building I just acquired. This was originally a fire station, all brick, built in 1905. Pretty basic firestation type of layout, two floors, roughly 25x60, main door for firetruck at one end has been walled off inside. In the 70's a block 42x60 flat roof shop was added to the east side of the building, this will be my shop for my business. The main building is oozing with neat OLD charm including a killer spiral staircase among other things. Now onto the mechanicals - There is a main 140k HVAC unit in the shop that feeds the firestation side. Currently it is only heating the lower level. There are other heaters that heat the shop side. The building has been upgraded to 200 amp service, feeding the downstairs of the firestation side and feeding the shop.
Basically where all the work is needed is in the upstairs of the firestation. originally it consisted of a large room where the fireman slept (still has the provision and hinge floor opening for the brass pole ), a bathroom, a locker room and a large 24x25 kitchen. This whole area hasn't been used since the 50's when it ceased being a firestation. Since then it has been some electronics businesses and the upstairs was walled off. My plan is to turn the upstairs into a nice 1500' loft/ apartment.
The plan is to kind of treat it as new construction upstairs, just gut it and start new. New water needs run upstairs to the locker room, which is becoming the laundry/ utility room. A hot water heater will be there, and distribute new water lines from there to the laundry/ bath kitchen. There is currently a 60 amp box already up there as previous tenants must have thought the same idea at one time. My first debate is to either run that and be done with it, only issue was I was not wanting to have to run gas upstairs and thought about running an electric stove/ dryer/ water heater. It doesn't sound like this is gonna work off a 60 amp. Alternative is to have a 100amp service dropped in just for the outside.
This is where I start running into cans of worms. I'm not trying to do this whole thing with no permits and completely illegally, but on the other hand I know there are things I can get away with here and there. Obviously to drop in a service I have to have a licensed electrician come set that up and have it inspected before the power company will drop the line. At this point with an inspector inside, he would have to be blind to not notice the shambles everywhere.
Now onto some of my questions....
Do I have to have an actual "company" do the work to have it pass inspection/ permit, etc or just a licensed person?? For instance I have a good friend who is a licensed electrician for a company and I asked about having them give me an estimate and he said he would just do the job himself. I realize this would probably not be insured bonded/ etc, but if he could do the work and is licensed and the permit/ inspection process passes, that would have to do.
Next, the answer to my last question might answer this one, but I just wonder if the same would apply for the plumbing? This is the one that is hurting the most. I have gotten "buddy" estimates from actual companies in the $5k range for running 30 feet of copper pipe in pretty easy to get to place. I have had side guys look at it and quote me $200 and a case of beer to do the same thing. This is one that's gonna kill me. I wonder if I should have these pipes run now and just say they were that way when I bought the building and have it done before the first inspector comes for the electrical, or if that just won't work out.
Other than that are just basic permit questions. Obviously I have covered plumbing and electrical. Do you get permits for basic construction like the new drywall etc? Permit for HVAC needed to add a couple vents and lower a cold air return? Permit for replacing windows? Does this more basic work need to be done by licensed people/ companies also??
I said that I have very little knowledge on this, but rest assured i won't be doing in important work myself. I have many friends, both electrical guys in training and buddies that can do plumbing etc. I am coordinating and doing basics like drywall etc. Things like the new windows will be done in the springtime by professionals.
If you made it through all this I appreciate it and any response. I do have one more thing to throw in the loop here. My house has been sold and I know longer own it in 9 days and will be staying in this building. I don't have any other choices other than a hotel or something. There are other areas I can setup for bed and other bathrooms, but no shower or hot water. I am thinking truck stop shower or a YMCA membership for a while...man...life is gonna be fun. Bit off more than we could chew?...yup - so you don't even have to tell me
Thanks!
Thanks!
