Lighting cord advice
Welshie
Midwest
I'm looking at getting the following lighting bars for my 20x20 garage:
https://www.amazon.com/dp/B074CY2HHC/?tag=atomicindus08-20
I will need extended cords for them with the layout I'm having, and the power will come from the current light which I will remove and use an adapter:
This will allow me to control the lights with the wall switch. My question is, what is a good way to hide the cables linking the lights?
theoldwizard1
SE MI
If you currently have the typical porcelain bulb holder mounted to an octagon box, buy a cover plate punched for a duplex outlet. Cheap. Easy.
You can find surface mount conduit that looks reasonable.
W
Welshie
Midwest
Those lights plug into each other. No separate power wire is needed how ever mine did come with a few 6in extensions.
Yes they CAN plug into each other, but I want them paid out in series, so will need a power cord to link them. My question is what people do with the extensions in terms of covering them or not.
Can you elaborate?
Would that bulb-plug adapter meet code?
I would assume so, how would I find out though for certain? Codes are new to me.
