Josh662234
- Joined
- Sep 23, 2011
- Messages
- 50
I just sold my townhouse with an 18x8 attached, and moved on to 2 acres with a 1900 sq/ft home and a 24x40, wooden structure, Morton building out back. The garage has its own driveway, and is tucked well behind the house.
I'm not nearly as smart as a lot of the people on here so this will take time, and I will be asking a lot of questions.
History: This building has been up since the late 80's. The gentleman that put it up was an electrician and intended to use the garage as a auto detailing space for his son. Apparently this never came to fruition, per word of the neighbors. Since this family moved out, two others have owned the property. 2 owners ago, the garage was used for lawn mower parking, and a party room/bar, so basically they never really went out there. The next owner occasionally worked on his mustang, hence the lift install. Really, nothing has been altered or repaired since the original construction.
To say i am overwhelmed is an understatement. The garage is great, but not nearly where I want it. This will be a long transformation as the house needs work as well.
The garage will be the main focus of this thread.
Pros:
-Size
-6+" thick concrete pad
-Lift
-Separate driveway (although it is unpaved)
Cons:
-The garage lighting is awful. All of the walls are unpainted plywood. It is very dark.
-A lot of the light switches don't do anything, all of the fluorescent lighting does not work.
-There are two 10x10ish rooms at the front of the garage, with a (very creepy) loft upstairs. I feel like this is a giant waste of space, as i am just looking for a large garage to park/work on my own and my friends vehicles.
-It is a very ugly two tone brown
Early focus:
lighting - i need to get the fluorescent lights working again. this may require a scissor lift and an electrician. I did one lowering spring job in there already and I needed a flashlight and a drop light at all times.
**Any LED replacement advice would be greatly appreciated**
Organization/layout - I need to sketch out some different options but i feel like removing the loft, and the two rooms, will benefit me greatly. I may keep one, and make an open air loft for parts storage above it. Anybody with a similar size, single door, garage please chime in.
Eventually:
-Drywall?
-1 big ceiling fan to replace the 3 home/living room ceiling fans
-Paint the building
-Pave the driveway
-Remove the 1980's era 7K lift and replace with a 12K that can support my truck
-Install an additional, 4 post, lift for winter storage $$
(what is everybody using now that communists took Photobucket over)
Pros:
-Size
-Lift
Cons:
Early focus:
Eventually:
-Drywall?
-Paint the building
-Pave the driveway
