Emt. Ground wire to receptacle
PoorOwner
CA
Running emt with no ground wire. Is it true the receptacle ground don’t have to be tied to the metal box if I use the cover that has recessed corners ?
alfredeneuman
Fullerton, CA
If you're talking about a surface mounted box, with a surface 1/2" 'raised' cover, then some inspectors look at differently. Some will pass it if the cover is the same brand as the box (ie: Raco, Steel City).
Some look at as "the cover might separate from the box if the mounting screws loosen" (a definite possibility) and won't allow it.
To be on the safe side, run the ground wire from the receptacle to the box. Grounding pigtails are cheap insurance.
P
PoorOwner
CA
I was thinking about this picture that I saw earlier
outlet-jpg.414763
matt_i
SE Michigan
If you have Menards, they have the stranded 12awg jumpers with 10-32 screw and a fork terminal on the other end. I believe Ideal also makes a stranded version of same.
If working with stranded I hate to introduce a solid into the picture, but thats just me.
sberry
Brethren, Michigan
I twist them around screws all the time. reverse twist it and its pretty secure. The outlets are designed a bit different but twist hundreds and even thousands of them and never a problem. I got a box of green screws and a box of forks too, make them up with fork on one end all the time, usually from scrap wire, takes a minute. In some places even crimp an eye on it.
dscheidt
Code says the cover is good enough, if the device is attached to the cover with suitable fasteners (which include the serrated nuts included with good quality covers, but also things like rivets), and the device is listed for such use (which means it's got a copper jumper around one of the screw holes, in most cases.). 250.146 is very clear on how to meet the requirements.
dscheidt
Well I guess I will probably add it, helps to hold the receptacle while I am wiring those boxes mounted on the ceiling!
Wire the device on the ground, with pig tails. Then you just need to attach your wire nuts, and screw the cover in place.
