Vote for the Worst Harbor Freight Item
MrSurly
East Texas
The philips headed bit stripped out on the first screw, cheap pot metal..
I've been watching as they've been bringing out all these new brands... It seems like some are pretty decent, but everything that says Warrior is pretty much crappola.
ScottsGT
Lake Wateree, SC
Heat gun. Switch went into high mode only after 3 or 4 uses. Had to plug in/unplug to get the job done, then trashed it.
No luck with abrasives. Wear out quickly.
Rivet nut insert tool. No rivnuts available in their store once you use what comes with the tool.
TravMan_63
Illinois - Springfield area
Scissors broke... cutting paper (bad rivet - easy fix) - they were free.
'quick clamp' - so cheaply made
worst for me was a tubing cutter - didn't notice the wheel nicked/not centered - messed up my brake line flares :mad:
bubinga
The red rubber air hose that they sell separately but also put on the reel. I live in Reno, and less than a year after buying the hose and throwing it up in my garage rafters it had thousands of micro cracks and wouldn’t hold air. I only use it once or twice a month. Replaced the red hose with the hybrid neon green one and it’s worked awesome for years now.
I live in a fairly rust free area, soy experience might be jaded, but after years of messing up rotor screws someone turned me on to using my 18v impact driver with a #2 phillips bit. I have yet to have it not work for me, just in case you’ve never tried it.
Why l quoted this post IDK?
So I'll say something about air hoses I guess. L0L...............
I have the flexzilla, but have not used it much.
They say they are good, but get dirty easy.
Guess I'll use it in the woodworking shop.
have the shorter 1/4" one from Sears, But it's a good 20 years old,
Nice to handle, on a Blow gun use.
0f course, lower air flow, not as good for impacts.
I know what is poorly made.
The wheels on the Big Foot blue dolly.
Nothing New here, been said before though.
broke after 2 weeks light use.
I didn't have No where near the 700# weight limit on it ever.
(150# max i'm guessing)
I will say HF should do a recall on those and at least give us good wheels to put on our dolly.
finn
The UP, God's country
There has been parallels discussed between the Canadian Princess Auto (PA) and HF. At PA if you are not happy with a product it can be returned I believe for a full cash refund. I had an air driven Power Fist (their brand) pad sander which blew up. I junked it. I was told later that I could go have gotten warranty. What I am asking is do you have any recourse on returns/warranty at HF?
Nearest HF store is a shade over 200 miles away. Not worth th aggravation to make a special trip to return junk.
Funny thing, though: many people complain about their 4” pneumatic cutoff wheels. They wear fast, but they are inexpensive, and I never had a problem with them.
Add to the **** list: red plastic dead blow hammer explodes in cold weather.
Blur powder coated welding cart sheds the powder coating in sheets. The Chinese kids making it must have forgotten to degrease it before spraying the blue powder coating.
Air fittings are hit or miss. Some work fine, others leak like a sieve.
Hoses on the pressure blaster turned hard as a rock after a year.
Looking over this post and my other one, it seems that the majority of my issues have been with plastic or rubber components of their products.
I think the plastic and rubber is what gives their stores that funky smell, too.
6PTsocket
Almost everything has at least a 90 day exchange or refund warranty. Some have more, even lifetime. Some items have a restocking fee if they feel too many people are "renting" them. Some products are eligible for a purchased extended warranty.
Bigblue&Goldie
Reminds Me of the alternator and power steering pump pulley puller and installer set.
I used the GM dealership set for years without problems.. The HF clone broke on the first attempted use. I use combination wrenches and apply torque slowly and evenly. It broke with little effort.
I forgot about that one......I had the same experience. My Kastar set (that HF copied) works perfect every time.
ARFLY
NW Arkansas
The only thing I have bought from HF that didn't work was the hole saw kit 68114. It was bad. I tried to cut a 2" hole in a piece of 3/4" MDF. It didn't cut half way through before the blade burned out.
emeraldcoupe
spring hill, florida
I have that set and have used it multiple times, works great for me. maybe I got one from a different factory :lol_hitti
Two Door
Houston, TX - USA
Ball joint press. Axis of the screw side not aligned with the axis of the receiving side so not possible to do a straight-in press.
Instead - Press in cocked to one side, rotate clamp 180 degrees and counteract. Throw clamp into scrap pile and buy a good one. Regret buying too far in advance of job to take advantage of warranty.
bwringer
Indianapolis
Their assortment package of hose clamps are really terrible. Strip almost immediately
Agreed. Their fastener assortments are awful, too. I believe there were lawsuits around the automotive fuses...
Snap Ring Pliers.....enough said.
Yep. That's all a friend of mine had in his garage, and, well, we had to make the trip back to my place.
The 99 cent socket rails. When there too tight they dont work. Too loose they fall off. There a b*tch.
Yep. The metal socket rails **** hard.
However, they sell a set of three blue plastic socket rails for something like $3 that ain't half bad at all. I prefer locking rails for my daily use stuff, but these are cheap as hell and work great for the stuff that I don't use daily. Plus you can mix-n-match the clip sizes on the rails.
6PTsocket
Never tried the drill bits but gave had very good luck the step bits.
I have the Silver and Demming drill bit set (large bits with turned down shanks) that comes in a nice wood case. I have drilled mild steel with no problems. Drill press, go slow, lots of lube.
6PTsocket
I lived for a long time where the nearest HF was about 300 miles. I'd heard about how they had incredible bargains in tools, so went there on a trip and bought a few things. Don't remember what they were, but all turned out to be garbage. I didn't try them again for years. Then, stopped by one when I was out of town, needed to tie something down in my truck that I had bought, and bought two packages of ratchet straps. When I got them out and tried to use them, turns out they aren't ratchet straps, but some kind of buckle arrangement, that didn't work particularly well. Once the strap came out of the buckle/latch thing, I'm not smart enough to put it back in, so I just use them for strap extensions now. Amazingly enough, still find them in my truck occasionally, they don't wear out because they don't get used.
Then, bought a $99 hoist to load something heavy when I was out of town. Worked okay for that one use, but at home it leaks all the time. Bought a second one under the same circumstances, it doesn't leak.
Bought a box of nitrile gloves there, used them for mechanics gloves and thought they were good, so bought another one when they ran out. I opened them and used some for painting last winter and they were okay, then this week had to put on 3 pairs before I got one that didn't rip. But, the ends of the fingers fell off after using them for a bit. Apparently, the nitrile somehow deteriorated in the past few months since I got them. I've had other brands for years without deterioration, so they must have somehow decreased the quality on the ones they sell. I bought a HF floor nailer from a guy at a yard sale. Unused, he had bought it and not done the project. I nailed about 2000 sf of floor with it, about 15,000 nails. At first it worked great, but by the end was jamming and had to be disassembled about every 50 nails. It has worn so that it double feeds nails. My 1970's porta-nailer hasn't worn at all, and has been used many times, probalby 100 times more than I used this HF one. I guess for a $20 yard sale purchase, the HF was worth it, but I'd be a bit irritated if I had bought it at the store.
My experience with HF has pretty much been that they are inexpensive, but not a good value if you intend to use the item more than cursorily, or as a throw-away. Probably okay for their target market, the lowest price, need for one job homeowner or renter tool user. Not a good choice for extensive or professional use, or for more demanding use.
Again, it depends on the item. I have been pounding on the original 1/2" Earthquake impact wrench for years. Their better line of impact sockets are good. The 44" cabinet set has stood up very well and is well reviewed. There are more than a few turkeys but there are some good deals. You just have to be VERY selective. Somebody complained about the ratcheting tie downs. I just used one as an emergency bead expander on my pickup tire. It bailed me out.
finn
Add another item to my list: orange ratchet straps. I was tying a beam to the tractor loader today, using a red Menards strap and an orange HF strap. They look similar at a glance, but the webbing on the HF strap is probably half the thickness of the Menards strap, and the metal is much lighter gage.
Both seemed to be working for the task at land until the plastic cover slipped off the handle on the HF ratchet at an inoportune time, while I was holding the beam.
Fell off twice, in fact. Poor design with no tabs to hold the lever cover on.
Ready for next weeks garbage pickup.
Tanro
The free multimeter didn't even make it out of the packaging before the leads had pulled loose from the wires. It was promptly tossed into the trash.
Lol I've been using those leads on my equus meter for a year or so.
Just bought some new ones bananna plug style ones with gator clips, regular probes, and back probe pins, and clip on piercing probes.
Tanro
Chrome wobble extensions for $10. They operated, but lasted all of 3 uses before the pot metal was deformed and sockets would no long fit in the male end of the extensions.
I've had a set of those for years, and been using them daily. I broke one on a long handle ratchet. But they swapped out the whole set.
Otherwise they've held up fine.
6PTsocket
The leads are garbage but the meters work quite well. I compared the DC voltage readings with a $300 meter and they were quite close. Few general purpose meters have a transistor test function and a battery checker that tests under load. Not bad for free I have a few of those meters scattered around. The lead problem was easily solved. I got a bunch of very nice test lead sets on ebay for $.99 a pair including shipping. The meter is definitely worth a $.99 investment. With any meter from an HF to a Fluke, test leads are a consumable, like screw driver bits. Throwing it a away was a real waste.
woody 73
The Great State Up North
I don't know if this counts as the worst ? But on the day I walked into there store they had a small box of drill bits and taps, (I think maybe some package opened up and the contents must have spilled all over the place?).
Instead of throwing them away they just wanted to sell them and I think I must have paid something like two dollars for that small box. Well long story short version the drill bits all broke and either the tap were very brittle and broke or they became very dull after one or two times of useage.
I figure nothing lost because I paid so little for them in the first place.
bwringer
Indianapolis
M_George
Eastern Pa.
The wire is poorly stripped and soldered on the leads. Just strip it back cleanly and re solder them. I keep one in each car's road tool kit.
Tanro
I can't really use more than one meter, and while the equus isn't a fluke. It does everything I need it too. I just melted the leads doing something stupid with them. I was at harbor freight, had the free meter coupon. Used it to get the leads, and they last fine, and ohmed out fine.
DanielC99
Central Arkansas
High speed metal air saw. Well oiled and plenty of air. Gutless, probably could have held the blade and kept it from moving. Trashed it and bought an IR.
theoldwizard1
SE MI
dreidel ? I actually googled that and it is a real word. a wooden jewish toy/game played during hanukkah. learn something new on GJ all the time.
The neighborhood where I grew up had more Jewish people than Gentiles even though I was less than 3 blocks for a good sized Catholic school and church !
My Mom's big shock was when the local baked goods delivery guy stopped by and offered her a loaf of Jewish Rye Bread for free. "But I am Catholic !", she gasped. "I don't care lady. It is god bread !" :lol:
I still love bagels. Only one real Jewish bagel shop for many miles around !
nbpt100
Massachusetts
The Twist drill bits. Dull and break easily. Ok on wood or plastic but don't waste your money if you plan to use them on Alum or steel.
6PTsocket
The odds are good that not every lead falls apart instantly. The wires are very thin and the insulation is thinner. The banana plugs are much shorter than normal and I and many others have had them fall apart. If they got you out of a jam, great but that does not make them anything vaguely resembling quality. Just look at the difference between probes, banana plug and wire insulation. The ebay ones even came with tip guards. We are camparing the HF to one of a pair of a $.99 cable set.89f457e651f2039422bc35faf0b25c51.jpg
nutsnbolts
Seattle, WA
A crowbar that was huge, like 1.5" thick, and broke clean in half yanking down ship lap off the ceiling in my basement. I'm not THAT strong
