Diesel DEF fluid 2 for $10
fourjeepin
Atlanta, GA
At NAPA corporate stores. Normal price is like $16 apiece. 2-1/2 gallon size. Valid for the month of August. My diesel doesn’t need this stuff, but I thought I would share.
48548
Phoenix
Thanks. I might pick up two jugs.
looking for a pebble 4766 or any 47xx pebble hinged handle
EOC_Jason
Bentonville, AR
Thanks, that's a really good price... I might have to grab some later this month as I just filled up not too long ago.
06 DIESEL
Middle River, MD
Just an FYI, if you have a place that has it at the pump it is a lot cheaper than this is, even on sale. I am glad that my truck doesn't take this stuff anymore, which reminds me I have half a tank of it I need to get rid of.
Hubmonkey
OK
Make sure you look at the date code on the jugs and check to make sure they are properly sealed. DEF does go bad...
Hub
ishiboo
Oshkosh, WI
I don't think pump DEF gets as low as $2/gallon around here. I usually buy the 2.5s and they are $7 on sale so $5 each is a pretty good price.
Hubmonkey
OK
As many problems I have had with the DEF system on my 2015 RAM, I don't buy anything over 6 months old...
48548
Phoenix
I keep them in my fridge.
drifter_r6
Went to a Napa, they had the "2 For" blacked out with a sharpie, selling for $10 each
BroncoAZ
My Passat TDI only uses 2.5 gallons per 10K miles, my 2011 Touareg TDI was good for about 4 gallons per 10K miles. The dealership charges me about $16 to fill my car on my regular service visits. Under the 11 year 162K warranty on my car that covers engine/fuel/DEF systems I want all service items documented by VW so there should never be a denied warranty claim.
What is the consumption rate on the 3/4 ton trucks?
Hubmonkey
OK
I get about 6k miles on the 5 gallon tank unless I am pulling then it really depends on speeds and conditions. I burned 5 gallons in 1300 miles on my last trip with the Travel Trailer to Yellowstone.
Hub
48548
Phoenix
If it is wrong, i will stick to the supertech walmart brand...
Fudge0514
Oklahoma City, OK
I used to buy SuperTech from WM as well, but then I found some DEF at my local Atwoods for even cheaper. $6.99 for 2.5 gal.
F
fourjeepin
Atlanta, GA
Deal is still on at the Woodstock GA location 2 for $10. I was also in the Sandy Plains Ga store and they had changed the sign to 2 for $20.
