Fidelitech
In the shop now there is existing PVC pipe and I need to connect to brass fitting. Best way to seal this is???? Just use teflon? or is that special goop to use when mating these two.
when transitioning from PVC to metal, always screw a male PVC thread into a female metal thread. Screwing male metal into female plastic can cause a crack or split in the female plastic fitting when you tighten it up.
you can glue a PVC fitting that has either male or female iron pipe thread on the other end, from there you can screw on a brass fitting that also has iron pipe thread. DO NOT waste your time with thread tape, it simply won't seal on PVC to metal, or PVC to PVC pipe thread fittings. Use thread dope instead.
Charles
Pipe dope and thread tape are lubricants not sealants. Threaded joints are in and of themselves what makes the seal, not the lubricant. The lubricant simply allows the joint to be completely tightened so it functions correctly.
