HELP used the wrong cleaner on aluminum
Kpaige
Big Lake Minnesota
Ok
This is 100% my fault. I used zep purple industrial degresser in a heated ultasonic cleaner on some carbs. Well it turned all aluminum parts a gark grey and it will not wire brush off or polish off at least easily.
The pic below shows the result on the left and the one on the right is after an hour with aluminum weld cleaner.
Any thoughts on a chemical that I can soak that will remove this?
maxpat82
the left one is the regular aluminium gray.
the one on the right is a "painted flat black"
the one on the left have been kinda stripped of it's paint
K
Kpaige
Big Lake Minnesota
Incorrect these were raw dull aluminum. I put them in the ultrasonic cleaner and it turned them thatvblack color! The one on the left is after an hour of brass brush with welding oxide cleaner.
maxpat82
sorry misunderstood
glass bead or steel brush wheel on a grinder.....hand brass brush is way too soft and would take forever(as you see it)
toplessHO
central florida
unless they are made of unobtainium I would look for others to rebuild
and sell those to someone that wants that look. Says right on the container
not to use on aluminum.
I did a small part made of aluminum with the purple cleaner and freaked when it immediately foamed up.Its etched the finish similar to a dyeing process
OccupantRJ
Eastern North Carolina
Depending on the look you are after, I have bead blasted aluminum parts and then sprayed a coat of clear on them for a rather unusual look. As far as what you have, the pro truck fleet pressure wash guys use an aluminum brightener on aluminum truck surfaces. Some of that might help, not sure at this stage.
bochnak
Mt. Prospect, IL
Paying someone to vapor blast them would cost $100, and he will have brand new looking carbs. No one is going to want carbs lookin like that.
Paint or even powdercoat will not last on carbs. It will eventually bubble off.
Mark_17
Don't use a regular steel wire brush or wire wheel. Use stainless steel.
MoonRise
You used an alkaline cleaner on aluminum.
The cleaner has etched the aluminum and turned it a dark grey.
Luckily you took the parts out of the alkaline cleaner before they were completely dissolved!
There is no chemical that will make the aluminum shiny and bright.
You would have to remove the grey aluminum oxide layer mechanically (grind, buff, polish, media blast, etc) to get back to shiny aluminum.
Or just go with the grey anodized look. Take the grey aluminum parts and simmer them in water for an hour to really 'set' the grey color (look up anodizing for specifics on the 'boil in water' stage).
At least the grey came out pretty uniform. :lol:
K
Kpaige
Big Lake Minnesota
Ook
To all yes I screwed up! I admit that right in my post! I was not paying attention and put the wrong cleaner in. So I suffer the results.
Yes I could run them that way but they are my sons so really want to get them close to start.
I will check into the vapor blasting that sounds promising!
Steveodle
Southern part of a very corrupt state
Ok
I used a lye soak to take the **** off of an S+S carb one time.
However sodium hydroxide is dangerous and will burn you and destroy any AL
That is left in it!
Test piece only, first!
If you do nothing right,you'll do nothing wrong!
K
Kpaige
Big Lake Minnesota
Going with vapor blasting.
And mukinis are a combination of magnesium and aluminum. Which one is more prominent depends on who was mixing the compounds back then and what what forge was running.
