Advice?
Yeah.
Do GMAW with C25 and a **** joint. Use 0.025 solid wire.
Lap joint WILL trap crud and moisture behind it, leading to rust from behind.
FCAW on automotive work will usually lead to failed paint from FCAW residue.
FCAW burns 'hotter' than GMAW (due to the higher current density through the electrode and the chemistry/physics of the arc and the metal transfer). Which leads to a much easier result of blowing holes through the sheet metal. 0.035 FCAW wire can blow a hole through 1/8" thick steel with a 'small' welder not even on MAX.
Use the 'right' tool(s) for the job and results are usually better than using the 'wrong' tools.
FCAW and 22 gauge sheet metal is the wrong tool for the job. IMNSHO.
Even with GMAW and 0.025 wire with C25, you should practice a bunch before hand. You can still blow a hole right through 22 gauge steel with GMAW.
And the procedure for welding thin sheet metal is NOT to run a bead along the joint seam.
You line up the pieces in a **** joint, clamping them as appropriate. Make a weld dot that actually achieves penetration/fusion into the base materials (not just a superficial 'tack weld'). Go to the other end of the joint, and make another weld dot. Then make a weld dot in the middle of the joint length. Let the metal cool off. Maybe you gently grind down the weld and also planish the seam. Then you make a few more weld dots. Grind and planish. Repeat until done.
Look up MP&C's project page here on GJ for some pictures and descriptions of welding automotive sheet metal.
