The toilet in my shop bathroom really, really *****. It gets plugged if you give it a dirty look.
It is a first generation version of the 1.6 gallon low flow toilets, which are all bad, but, something is wrong with the fill valve on mine because the water does not fill up to the water line in the tank, (about 3/4" low) so it's even less than 1.6g.
In the old days you just bent the float a little to adjust this. My entire valve assembly thing is plastic and I have no idea how to adjust it. Maybe I should just replace the whole fill valve? Additionally, is it possible to modify it a little bit so that the tank actually fills HIGHER than was originally intended? I live in Oregon, I have no reason to "convserve" water and am not interested in plugging my toilets to do so...
It is a first generation version of the 1.6 gallon low flow toilets, which are all bad, but, something is wrong with the fill valve on mine because the water does not fill up to the water line in the tank, (about 3/4" low) so it's even less than 1.6g.In the old days you just bent the float a little to adjust this. My entire valve assembly thing is plastic and I have no idea how to adjust it. Maybe I should just replace the whole fill valve? Additionally, is it possible to modify it a little bit so that the tank actually fills HIGHER than was originally intended? I live in Oregon, I have no reason to "convserve" water and am not interested in plugging my toilets to do so...
