I have a 5 ton unit that's about 20 years old I think. It was running Wed, and I lay down for a nap. When I awoke 3 hours later I knew it wasn't working before I even got up. The attic blower was running, but the air from the vents was warm. Shut it off right away.
Both compressor and condenser fan are not working. Makes me think bad cap. BUT I also ohm'ed the start and run coils. Got 1.9 ohms on the start coil to common, and .1 ohms on the run coil to common. That seems way too low. Start to run, I do get 2.0 ohms.
Compressor is a Carlyle 5 ton, SRD600AC01.
Next step, I will confirm the contactor is working, and I will probably replace the cap, as it does look a bit poofed, but I am guessing both the cap and compressor are toast.
Can anyone confirm? Any other troubleshooting I can do on this? Wish I didn't let it run so long when it was out.
