I ha ve a detached 30' x 30' (outside dimensions)8" block garage with 2"x4" wood truss roof. Inside dimensions are 28'-9" x 28'-9". Top of the block is 9'-7" (eave height) and peak height is 14'-10". The garage is not insulated whatsoever. I have two uninsulated aluminum panel overhead doors, one regular access door and 3 single pane standard windows (cheap...mainly to keep the wind and rain out). I do not have a ceiling. It is also equipped with a 200 amp eletrical service.
As you can see by the attached photos, I presently have two sources of heat I can use. The first and present source is a double barrel wood stove, which can be quite cumbersome to fire up all the time and wait for a couple of hours to warm up the garage. The second source could be a Hastings fan forced natural gas (Model F120X) heater rated at 120,000 bto maximum input and 96,000 btu output.
I would like to be able to work in the garage at least 2-3 hours per night and at least 8 hours on Saturdays and Sundays.
I have not vented nor fired up the Hasting Unit. Just mounted it on the bottom of hte roof trusses. I received this in a barter situation...took it to the car wash and cleaned it up. Looks brand new after the wash.
I would like some advice on the most econimical way of insulating the garage (and addition of a ceiling if needed) so as to best utilize the Hastings Gas Fired Unit. It would be really nice to set up the controls so that I can just walk in and flip a switch and prepare to get something done.
