Is there a tool made for this security bolt?
evintho
Santa Rosa, CA.
I'm painting my house and need to remove this security door so I can blast and paint it. I need to find a tool to remove these 6 bolts that hold it to the door frame. The bolt is a larger version of what is used on commercial bathroom stalls. I know there's something out there! What's it called and where to get it? Thanks in advance!
J.A.F.E.
Formerly Area 49 now Area 52
One way screw remover is what you need. The driver looks like it has two pins in the end - I have seen them at Home Depot but the size you need may be bigger than what they carry. They work but you have to apply a fair amount of pressure against the screw.
jonesg
northern Maine/
Cut a slot with carbide disk .
L.Cheapo
If that were my problem I'd knock the paint off, weld a hex nut to them, and zip them out with the impact. Replace with new upon reinstallation.
Looks like a hassle, even with the appropriate tool.
NYBODYMAN
NY
It's a clutch screw you need a clutch screw driver/bit. You see these a lot in bathroom stalls.
joe_padavano
Northern VA
It's a clutch screw
No it isn't. It's an anti-tamper screw specifically designed NOT to be able to be removed without destroying it. A clutch head screw looks like this and was used on 1950s GM and Ford vehicles.
NYBODYMAN
NY
Hmm I was always under the impression they were called clutch. Thanks for the knowledge.
5ktq
Yeah, either use a die grinder to make reverse flats, or if its in something pretty solid you could do the same with a chisel (and also break it loose at the same time)
But since you're going to refinish the door anyway it might be easier to just grind them off.
1982fxr
Phoenix
Question, why such a security driven bolt for bathrooms?
So people can’t steal stainless partitions?
ChaseDE
Delaware
Humans are destructive by nature and tend to be bored and have a lot of time on their hands, in restrooms.
CoogarXR
And they were everywhere on 80s and earlier mobile homes too.
Dave455
Sussex, England
O.k. The screw shown by the O.P. is a one way screw, designed to be hard to remove!
Actually, very easy to remove - simply file or grind off the ‘ramps’ and simply use a regular screwdriver!
Removed a load this way!
Joe From NY
NY
Angle grinder to take the heads off, pull the door off, remove screws with vicegrips.
This.
I had to remove child fall window guards to install an A/C. They had those stupid screws. I ground the heads off with my 4 1/2 inch grinder, then hit the remnant with a punch. It did the trick. I believe destruction is the only easy way.
driftpin
I'm with those who use an angle grinder to slot the screw and then just use a snug-fitting blade screwdriver bit in a driver drill to remove them. Much-easier than having to grind-off the entire thing, which stands a better chance of gouging the door frame.
619DioFan
San Diego , Ca.
Some hardware store near me had a tool that was supposed to remove them ( basically a reverse tool of the install tool sold for them ) it didn't work. used my sawzall with a metal cutting blade , went between the bolt head and the frame. worked well for me. vise grips removed the remains once the frame was off.
jimindm
Des Moines, Iowa
FigureItOut
Bentonville AR
I'm glad I read through the posts before posting my suggestion. That is a perfect use case for Vampliers. Mine come out a few times a year, I wouldn't ever be without them again.
Sent from my SAMSUNG-SM-G930AZ using Tapatalk
FANTM58
Brighton, Co
I would take a mini grinder with a slicer disk , and cut the slot deeper
Then a straight screw driver will Handel it !
disston
Silver Spring, Md
I bought a clutch screwdriver over 45 years ago to adjust the door latch on my 1954 Ford. Still have the screwdriver, don't have the Ford. Used the screwdriver once.
In all these years and working on various machines I have never seen a fastener used on any type of a clutch that used this design.
