File Use and Care Questions
Bolster
Mexifornia
1) To keep a file from loading, you can pass it over something, but I forget what. Chalk? Soap? Wax? Can't remember.
2) If you look at a file and you can see that some of the teeth are pressed down, leaving a "shiny stripe" on the face of the file, is that an indication it's time to toss it?
3) Is it bad to oil a file (to keep it from rusting)?
4) I heard of a "file resharpening process" that was essentially putting a file in an acid solution and allowing some of the metal to be etched away. Anybody tried that with any luck?
5) Any good ideas on how to keep files in drawers? I've cut tubing to surround the files, so they don't knock, but it is ugly, it obscures the file so you can't see which you want to use, and it fills up the drawer fast. Not the greatest solution. Would like to see some creative file storage solutions.
michaudracing
Atlanta
5) I use the rubber mats used for storing music CDs, as found at Ikea. They're only about 3/8" thick, hold 20 files each, and are dirt cheap. The rubbery plastic makes it easy to cut a divider out if you need a slot for a wider file.
Zrexxer
Pflugerville, TX
I wouldn't call it creative, but I bought a new set of Nicholsons awhile back and I just laid the roll they came in flat in the drawer. The others I had already just lay flat side-by-side at the end of the roll.
stricht8
Ok. But nobody has answered the loading up question. I don't know either but I do clean them every know and again with a file card. Also I thought that I heard something about rubbing them with turpentine probably on this forum to prevent loading and rusting?
stricht8
What do you all do with worn down files besides turning them into slapping files?
jteck75
Benton Ky.
I've got what I've always called a file card,just a brush with stiff steel bristles on one side and softer bristles on the other. It flat out keeps files clean,can't remember where I got it though.
Elroy
kentucky
File cards are readily available from any industrial MRO distributor, Elroy prefers a scratch brush and for really bad pins, a single edge razor blade. :headscrat
Stuey
28m above sea level
I've seen file holders that resemble wrench holders that keep the files upright at an angle.
Yep. I read that thread a while back, and because of you I kept kicking myself for forgetting to buy chalk until I finally remembered.
I've since had an odd question - what do you think would be better, powdered layout chalk, or sidewalk chalk sticks?
autoace
Maine,USA
I spray the file with some WD40, then use a brush and compressed air to keep the files clean, and get the crude out of them.
bchee
Texas
Do you have an Ikea link? I'm trying to picture what you're talking about...thanks
bgott
Houston, TX.
Golf balls make good file handles. Just wear safety glasses when you drill holes in them, some of them have a pressurized liquid in the core.
