Speed spinner, but not ratchet...
wolf_from_wv
WV
Not finding a speed spinner ratchet, https://www.garagejournal.com/forum/showthread.php?t=247030 , I had an idea...
Though it would not ratchet, would be feasible to take a sliding t-bar, trim the handle, grind a flat, and put some kind of flat knob on one side?
My other idea involved cutting a ratchet handle, welding the cut-off piece to the other side, and putting a handle on it, but I don't know how to weld...
larry_g
oregon
Take a sliding T handle and bend the end of the handle at 90*.
lg
no neat sig line
Al Borland
I have/had? one of those. it was in a car I bought. Not sure what I did with it. Didn't use it. Regular speeder was a hell of a lot more useful.
Kind of a "solution in search of a problem" tool.
rsanter
visalia ca
what are you trying to do?
what are you going to use it for?
you know they make speed handles
W
wolf_from_wv
WV
I was going to take a piece of 1/4" rod, chuck it in the lathe and drill both ends and thread them for a stop screw to keep the pieces from sliding off the ends. Then, I had an idea...
So, I made this today...
W
wolf_from_wv
WV
You get full points for doing it yourself. I'd look at it as a prototype, to prove the concept, now refine it into something usable.
Get a bolt with a bit more threaded part, and put a nut on each side, so it doesn't slide. Turn the nuts off round, so they aren't sharp and won't gouge your hands. Figure out a longer "bearing" spinner part for the handle, so that it will stay in place, and won't slide down. Or, cut a groove and put a smooth C Clip under the spinner to hold it in place. Make sure it's not sharp also, the best way would be to have a recess in the spinner handle piece so that the C clip is captive and hidden. Making the spinner a bit bigger around would make it easier to grasp, and would give clearance from the top nut hitting your fingers.
Round the nut on the top of the whole contraption off to a round, smooth surface that won't tear your hands.
I was thinking about the threaded part after I made it. I can't seem to find bolts like that with longer threads, but I guess that's what the tap and die set is for.
I guess I need something with a smaller bend radius than my vise jaws allow for.
The bolt head will definately need rounded off.
Air21
Or if you want to be fancy and forgo the nut: Chuck it up in the lathe and center drill the end of that rod. Then find the biggest broken carbide endmill in the shop and grip it backwards in the tailstock Chuck. Spin the lathe up to the highest RPM's it will go and crank the flat back end of your carbide endmill into the center drilled end of the rod, give it plenty of pressure untill you roll enough if the rod back to disappear the center drill holes.
I've replaced the bars on a few Chuck keys that way when the gorillas in the shop get caught using cheater bars on them.
Also... Why wouldn't you want it to be ratcheting? I use a speeder quite a bit because I'm in aviation, and the ratchet adapter on my speed handle is a life saver when I really need to put some torque into the fastner. I can reposition the speed handle to a more ergonomic position instead of either the 4 positions I get with a Philips head or the twelve I get in a socket.
5ktq
Start with the ratchet head of a flex ratchet, or head from a detachable handle type, if you want ratcheting, I guess.
You could just put a ratchet adaptor on your contraption, but they're kind of expensive and bulky, eg... probably add 2" or so
CR888
Ya this^^...you know ratchet adapters exist right? Often I fit my ratchet adapter to a extension length I need then put a sliding T on the end. Makes one big *** ratcheting T-handle. No fabrication required.
