mx842
There was this guy standing in his over loaded garage the week before last and stared at this big hunk of junk that his father left him several years before. He didn't know if it even worked as it was all rusted and banged up looking. He didn't want to part with it but his wife pretty much made the decision to haul it off to the dump because it was not being used and it took up a lot of her valuable space that she could use to put a bunch of her worthless junk.
He somehow got it loaded on his trailer and was headed to the scrap yard when he remembered that one of my sons worked on cars so he went by his house to see if he wanted it. He didn't want that worthless looking pile of junk but he said I know someone that will take anything like that no matter how ratty it was. That would be me. They rolled up in the drive way and backed up to my garage door and asked where did I want them to pile it up.
At first I didn't know what it was but then I spotted several buckets of tooling and took a closer look and could see it was a brake lathe disguised as a big pile of junk so I told them to back under my trolly chain lift and I would pick it off for them, All 759 lbs of it.
It sat in the middle of the floor for a couple days and because it was raining outside and couldn't work outside I decided to take it apart and see if I could maybe salvage something out of it. I wish I had taken some pics of it the way it was but before I knew it I had it mostly apart with the parts hanging on my paint rack. It took me three days to clean, strip, mask and paint that poor neglected pile of scrap but a little paint does wonders on an old machine like that.
It took me another couple days to figure out how to put it back together then it was time to rewire the thing because the power cord was banged up in a couple of places and the light and motor switches looked like they had fought a war and lost. Before I started to clean the machine I plugged it in to a wall plug and it popped the circuit breaker right off the bat so I knew the wiring was bad. I looked for three days on the internet for a wiring diagram and found a couple but they were pretty poor copies and I couldn't make heads or tails out of them.
It was wired for 110V but I wanted to run it off one of my welder plugs I have throughout the shop. I decided to scrap the way it was wired all together and do it another way. I added a box to the side of the machine where I could run my cord from with switches mounted on the top. I also added circuit breakers for the light and the motor.
Once this was done It was time to plug it in and see what would happen. I tried the light switch first thinking it would probably be less smoke and fire that could come from that circuit and when I flipped the switch the light came on like it should....no smoke, fire or anything like that just nice bright light.
So it was time to smoke test the motor so I reached over and flipped that switch too.......I mean, what's the worst that could happen so I hit the switch and nothing happened, no smoke, no noise out of the motor, no nothing. Then I looked at the circuit breaker I had added into the mix and saw that it was off. Wow...still another chance to see some sparks so I flipped that too and was shocked to see that the motor actually started and ran rather nicely so I put it in gear to see if the spindle would move which it did. I couldn't believe how smooth and quiet the machine ran. I couldn't try the table feed because both of the belts were toast and there were a couple other pieces I will need to get before I can try that part out.
I'm sure it will work if I can find the parts. Also, I will need to find out where all this rusty tooling goes. I did buy a manual off e-bay but I may as well have kept that $16.00 in my pocket because that don't tell you much. It list the tooling with a number but no picture of what that part looks like and there are no numbers stamped on any of the tooling.
If anyone out there has one of these Van Norman machines would you be so kind to maybe help me out finding where to get parts and maybe ID some of this tooling. Thanks
