Wamsutta
Top 10 Snap-on Tools sold off of Jeremy's truck.
Five tools per video:
1.
2.
1.
2.
Kind of surprised that a 1/4 drive metric semi deep socket set was his number one, most sold socket set though.![]()
most entry level jobs that have truck service won’t hire someone without a basic set of tools.
Thats why a lot of medium-large sized shops have apprentice and/or oil/tire positions for.
The last shop I was at, which I regret having to leave, actually paid up to 200$ for the oil/tire guys to buy tools as long as they showed up for the carquest classes when we had them.
Good idea considering a lot of the workforce is getting up there. Our techs were 65/49/44 and me being the youngest @ 29. Hell I was younger than 1/2 the tire/oil guys. Story is generally the same most places I've worked. Everyone that does anything besides oil/tire is generally 15-20 years older than me.
Is there a thread somewhere on the top ten tools where it's actually worth paying Strap-On prices?
I mean, there are lots of way to turn nuts and bolts just as well for a lot less money, but what I'd like to know is when the supposedly higher quality actually makes a practical, real-world difference and is actually worth paying five to ten times as much.
Interesting that the new crown handle pry bars weren't on his list. Also surprised that 1/4 semi deep sockets outsell 3/8.
In my opinion, SO's pliers are definitely worth the price tag. I recently sold nearly all of knipex and made the switch. Far superior pliers that you won't appreciate until you hold them in your hands and use them.
I suspect that's because Gearwrench or Carlyle 3/8" are perfectly adequate but the extra Snap-on strength makes a difference in 1/4"
Of course that is anecdotal. I haven't seen a statistically valid yield test preformed.
So what is more stressful to a socket, is turning 150lb-ft with a 22mm 1/2" socket more or less stressful than turning 50lb-ft with a 12mm 1/4" socket? Answer this question correctly & you will know where to best spend your hard earned on high quality tools.My 1/4 semi deep from gearwrench have been tanks, I'd almost go the opposite direction and say I'd want snap on strength in my larger sockets, as they'll be used on larger fasteners where more torque is required.
I would think Snappy line wrenches (which are still made) qualify as a top of the heap tool worth paying that premium. I have used them a few times myself to know.
So what is more stressful to a socket, is turning 150lb-ft with a 22mm 1/2" socket more or less stressful than turning 50lb-ft with a 12mm 1/4" socket? Answer this question correctly & you will know where to best spend your hard earned on high quality tools.![]()
I'm not sure, you tell me? I imagine based on the question and trends in this thread, its going to be more stressful on the smaller 12mm. Now my question is this, what if the 22mm socket has 3.2mm side walls and the 12mm socket has 4mm sidewalls? I imagine regardless of the stress being higher, the socket with thicker sidewalls would be harder to crack than the thinner one, all things equal.
I'm no engineer, but I was a mechanic and I've yet to break a socket that was used properly, my hard earned cash will happily be spent on good tools, where necessary![]()
I deduce that’s because it’s fairly new. The purchasing habits of established techs is going to differ significantly from those of FNGs.
We should assume that the highest volume of basic items are sold through the SEP since most entry level jobs that have truck service won’t hire someone without a basic set of tools.
I'm having a very rough time believing this. Snap On over Knipex?
For needlenose, I would take S-O over Knipex
Every.
Single.
Time.
The S-O Talon grips are superior to any other pliers I've tried. And yes, I own S-O and Knipex, among many others...
Agreed. Knipex for dykes and other cutters, pliers wrench and cobra. Snap-on for PWZ and talon grip needle nose.
Correct, as fasteners and socket/drive sizes increase the torque loading is spread out and is far less concentrated. The natural laws of physics tell you that high quality small drive hand tools are a good idea. Although I'm not suggesting a heavy equipment tech who uses 3/4" drive tools all day should cheap out & not buy quality either. What concerns me about sockets under stress is not the fact they may shatter or crack, I don't want the female drive end or fastener end getting deformed leading to reduced performance. The best selling 10 SO tools I imagine is far different to the best top 10 tools based of quality/design/tolerance/performance.[/I
Knipex makes Swedish-pattern pipe wrenches, wonder how they stack up against the PWZ.
Every.
Single.
Time.
... It didn't take long to realize they're probably the single worst tool I currently own: ergonomically unsound handle shape, poor quality joint machining, cheap finish, and shamefully overpriced. Every single other pair of needlenose pliers below is a superior tool for any use I can conceive of...
Same question I posed to sweet victory: why? I've tried them, I currently have a pair among 14-odd other needlenose pliers on hand right now. The Snappers are to me at least the clear laggard of the group.
The Bacho 140 series is the same as the PWZ without the rubber grip. Comically they are usually as expensive in the US as the Snap-on rebrand.
If you call them they will work with you on price especially if buying several. I bought 140-143 all at once and they dropped the price significantly,especially on the 143's. I think I got charged 75 each for the 142 and 143 and then 15-20 off each set of the others.
