My custom 14' tool trailer and workspace
BreeStephany
Oregon
View media item 86217I recently bought a 14' Cargo Mate cargo trailer and have spent the last couple of weekends converting it into a tool trailer and functional workspace.
View media item 86233The trailer had been used before I bought it for mobile pressure washing. The floor was soaked in diesel fuel and the entire trailer reeked of diesel.
View media item 86231After buying the trailer, my first task was to take care of the floor and to try to reduce the smell in the trailer.
I first removed the thresholds from the side and back doors and then painted the floor with an oil based block primer that was designed to prime heavy smoke damaged structures.
After letting the paint dry, I then covered the existing floor with 1/4" birch ply. I used heavy duty PL construction adhesive to bond the sheets to the existing floor and then screwed the ply into the steel cross braces below the original plywood.
After screwing off all of the flooring, I reinstalled the thresholds and began working on shelving in the trailer.
View media item 86232I used 3/4" birch finish ply to construct my shelves and then finished off the fronts with 3/4" red oak.
I constructed a set of angled shelves to hold my larger power tools with hard cases, then made a set of straight shelves to hold smaller boxes, soft sided cases, etc. and then made a set of smaller shelves to hold parts bins for screws, EMT fittings, etc.
View media item 86218A view of the shelves with all of my tools in place and parts beginning to fill up the bins.
View media item 86219For parts storage, I bought a Harbor Freight 47 bin floor mount parts rack and integrated it into the shelving. One of the main complaints of the HF parts rack was that the trays had no support under them, so I built shelves that the individual bins sit on and then used the metal rails from the HF rack to hold the bins against the wall.
So far, after making a couple of 100+ mile trips with the trailer and taking the trailer down some very rough gravel roads, I am confident that the bins will stay in place and shouldn't break because they are supported by the wood shelves.
As a backup, just in case a bin were to come loose, I installed 3/4" x 3-3/4" fronts on each shelf that were dadoed, glued and nailed into the plywood shelf / 2x2" shelf supports.
There is a 1.5" lip above the shelf to keep the bins from falling off the shelf, shall they ever pop of their rails unnecessarily.
They are designed so that the bins can still be removed, but will not come loose on their own.
View media item 86220The angled shelves work great in making tools quick and easy to remove, while keeping them in place while transporting the trailer from job to job.
View media item 86221I bought Rubbermaid FastTrack and FastTrack holders to hold extension cords, PPE, fishtapes, benders, shovels, etc. The rack is really great at keeping the holders in place, even with large amounts of weight on them, while still allowing the holders to be rearranged, shall the need arise, quickly and easily.
View media item 86222Tool belt holder, flexi-bit / fish rod holder.
View media item 86224One of the biggest reasons for getting a tool trailer was to be able to clean tools and charge batteries after work hours. I installed a 4' 12 outlet power strip under my charging shelf, hardwired it into the load side of a GFCI outlet and installed a 4' 4500 lumen LED vaportite strip light directly above the work bench.
Keeping the light directly above the bench prevents shadows while working inside due to the low ceiling height, while also ensuring that ceiling height was kept as tall as possible in the main traffic path of the trailer.
I currently just have a cord and plug installed for supplying the trailer with power, but I plan to install a recessed male plug with an inuse cover on the outside of the trailer so that the trailer can be plugged in while all of the doors are closed and locked.
View media item 86223Charging shelf. I currently have a Milwaukee M28 charger, a Milwaukee M12 charger, a Milwaukee 2.4V battery charger and a 2 bay Makita 18V charger. The shelf is designed so that chargers can be easily reconfigured, phased out, replaced, etc., all while keeping wires clean and organized.
View media item 86227Wrench drawer!
I picked up a US General 8 drawer 26" tool cabinet to organize some of my larger loose tools, extra loose power tools and smaller tools that were not in cases and those that were not commonly used.
I used Kaizen foam to shadow each drawer so that tools stay in place, even during transportation, and prevent tools from shifting, piling up and potentially preventing drawers from being opened.
View media item 86226Backup drill and 1/2" cordless impact.
View media item 86229Rivnut kit!
Its surprising how many times I have used rivnuts on the job as an electrician, and even more surprising how many times I wished I had a kit with me to accomplish a particular task.
View media item 86228Measuring tool drawer.
View media item 86225Had a couple of laminate countertop scraps laying around in the shop for years. I finally found a use for them. The joint between pieces isn't the prettiest, but looks great for a tool trailer and makes keeping the counter clean.
I used the mat off of the tool cart as a countertop mat to make cleaning up after cleaning tools quick and easy.
View media item 86230
View media item 86235
View media item 86234Just a few outside photos. Overall, I am very happy with how the project turned out and think it will be a very functional trailer on jobsites.
BreeStephany
Oregon
Sorry about posting images through Imgur, its been a while, everything is updated to working image links.
alwaysFlOoReD
Airdrie, Alberta, Canada
Nice job. I found that making the angled shelves taller uses less space. You can then have the tool boxes stand up beside each other. I use a paint pen to mark the sides of the case so a helper can easily find what is needed.
bluebolt
Benton LA
Nice work BreeStephany, organization and construction like this would sell me on using someone's services over a disorganized mess in a work trailer. .
Dumber than lumber
That is really nice. I use the angled shelf idea in my garage on a shop-built roll-around cart. Makes it easier to put tool cases and fastener boxes away.
PLEASE make sure that your trailer and equipment are ADEQUATELY INSURED. It would **** rocks to have an uncovered loss.
vavet
Ashland, VA
Things like this amaze me. You can take a small space and cram a lot of things into it and it looks great - very neat and organized. I have a 24x32 garage (5x the space?) and it looks like hell.
It is a constant battle.
Evan(CA)
How old are you? Your power drawer cab post is one of the first that drew me to this site. What kind of electrical work are you doing? I'm an electrician myself but your other post was in an airplane hanger IIRC. I noticed you only had 2 1"+ benders and I can't see dragging a trailer to every job unless you are working on a tract project setting up temp power
iajonesy
Iowa
Hi girl. Haven't seen anything from you since Christmas. You did a fantastic job on the trailer. Lots of clever ideas and great space utilization.
Sounds like school went ok for you and now you're out in the work force. Keep up the good work.
Mike
619DioFan
San Diego , Ca.
Sounds like a sweet project. sadly I don't see any picts.
OK..see the pics now. looks fantastic. for some reason after seeing the power tool cabinet for the snap on box that you built I thought you were a mechanic ( airplanes perhaps ? ) anyways , great job on that trailer.
gnpenning
I have more questions than answers.
Nice job! I agree with the others in saying nice job. If you need anymore counter top matter lmk. You can pick it up on your next trip north.
What's your plan on the ceiling?
I didn't see any of your polished tools in there. ..
LXCam
Excellent job on the trailer! I had a 14ft pace for our job site trailer which was perfect for the large benders and threading equipment. I'd make one suggestion for you to consider. Being I'd leave mine on remote job sites for weeks or months at a time. I outfitted it with a covertly covered large battery and built in charger over the wheel well with a external recessed male plug. This way I could have 120 plugged in and the trailer secured. Off the battery I installed an alarm with a GPS system that would alert me if it went off or if the trailer moved beyond a perimeter that could be set in the system. It wasn't all that much coin and really provided some piece of mind when left unattended.
Keep up the great work.
gte718p
Very nice build.
I recommend getting a boot for your trailer. It ***** having your hard work and tools roll away with some scumbag. It is much more effective then chain, but someone with a battery portaband or grinder can still get it, but it is a lot more work. Most thieves are lazy.
theoldwizard1
SE MI
A couple of tips.
  • You need wheel locks (like a "boot") with a disc type padlock so the the trailer can not be towed away
  • Rig some kind of brace/"foot" for the back end of the trailer. If it is NOT connected to a vehicle, you don't want the tongue going up when load/unloading heavy items !
  • I really like the heavy duty hinges and commercial trailer double door bar latch. Spend the money on a GOOD disc padlock. NOT Master Lock (Hint, look for a pair of Abus disc lock, but expect to pay a lot for them !)
Depending on where you park/store this beauty, consider some outside motion detector lights and possibly even a wireless horn/siren alarm with to a detector if the the trailer is bumped/moved at least the door is opened.
Miss the Pontiacs
Saskatchewan Canada
Why did you start a whole new thread?
I like the idea of a new thread. When I start a large thread I like to start at the beginning and watch the project evolve. The threads that are 50 plus pages take awhile to go through. So I only do one at a time when I have time. Some projects would be totally finished for some time before I would get a chance to see it.
BreeStephany
Oregon
In my early 30s. I just graduated Airframe & Powerplant mechanic school and secured my A&P license this spring, but after getting a significantly better offer to be an electrician, I decided to go back to wiring. I do mostly larger multi-family homes (10~200 unit size) and commercial with my current employer, though I have done a bit of industrial as well.
I can fit all of the tools in my trailer in my company van, its just that the trailer is easier to work out of when I know I'm going to be on a job for a while.
BreeStephany
Oregon
I am an airframe & powerplant mechanic, just can make better money, work normal hours and stay in Montana working as an electrician.
BreeStephany
Oregon
Do you have any linkage to the system you installed?
LXCam
No, that is now 20yr old technology and it was expensive since only one company was offering these systems at that time. There's much better systems and way cheaper now then what I had when I put that together. I also had the same set up for all the trucks too.
