Which Fan? High Heat exhaust from outside Shed/Closet
UglySign
Which Fan? High Heat exhaust for outside Shed/Closet
Here's the scenario...
I will be putting a CNC vac in a small shed outside along side the garage wall.
Area size is 84"w x 90"h x 72"d. Semi soundproof, more to be done.
This vacuum from what I am told can get up to 200* on a scorcher day.
Not good, what type of fan would I need, wall or roof mount? There's no
problem for intake air. No, I cannot keep the door open because it is really
loud.
Any recommendations for a fan that can handle heat? Maybe have a thermostat
to fire it up before it hits peak temps, get a circulation going.
Thanks! :thumbup:
U
UglySign
Re: Which Fan? High Heat exhaust for outside Shed/Closet
Why does this vacuum get so darn hot?
Link to this "Vaccuum" ? Interested. Marc
Well Marc, it's essentially 4 motors. Depending on the hold needed. you can run 1, 2 3 or all 4. They generate alot of heat the longer they're run. There are also homemade DIY kind out there, mine is not.
You can get an idea herefor what I have:
https://www.youtube.com/watch?time_continue=9&v=LDP4NUUKgCY
This should take care of your needs. I have one in my shed with my compressor and after cooler, haven't had a problem with it keeping up with the temps.
Master Flow1600 CFM Power Gable Mount Attic Fan
https://www.homedepot.com/p/Master-Flow-1600-CFM-Power-Gable-Mount-Attic-Fan-EGV6/205924917
OK... it's a thought. What about a roof mount? Otherwise it'd prolly work.
Who ever walks by might get their Toupée blown off.
Cheers!
bored350
Arkansas
I'm not a fan of putting holes on the roof, plus it wouldn't work well for my application. I have the fan drawing the hot air from the after cooler directly out the fable end through a louvered vent.
I also installed radiant barrier under the entire roof line and lowered the interior temps to 8° over ambient on a 102° day.
Sent from my Moto G (5) Plus using Tapatalk
theoldwizard1
SE MI
Large (the large the better) fans, spinning at low RPMs make less noise and still move a lot of air. Squirrel cages fans fan, like out of an old furnace, also work well.
larry_g
oregon
http://lumberjocks.com/topics/36276
I don't have a fan for you but the link above has a good description of a labyrinth noise filter. We used them on some vacuum pumps where I worked to control noise and they worked very well. Noise mainly travels in a straight line so the interlaced panels with noise canceling foam on them kills the noise but allows essentially free flow for the air.
lg
no neat sig line
U
UglySign
Thinking about it... nix the idea for the roof.
I dig, but not sure if im going to gave the room. Bigger they get the deeper they'll be. Have to kick some of these ideas around.
:beer:
U
UglySign
lg
no neat sig line
OK, maybe can combine w/ other ideas here.
I should also mention I have a Felder AF22 DC in there too.
That is essentially separate from this vacuum. Heat wouldn't be directly
on it.
