Searching for severe duty bulbs
cybrdyke
USA
They had to make a special version of the incandescent bulb, called "Rough Service" or "130 volt" to withstand vibrations, voltage surges, etc., for industrial use. It had a thicker filament. Still, it was pretty weak, just because filaments dont like vibration. Compact flourescents were a little better, but still not great.
LED bulbs have no filament. They are very good in high vibration areas. A good quality LED bulb will have better solder joints and better components than a cheap one.
Good luck,
CD
rlitman
Long Island
...LED bulbs have no filament. They are very good in high vibration areas. A good quality LED bulb will have better solder joints and better components than a cheap one.
Good luck,
CD
Many are. A lot of the best LED bulbs use glass exteriors that can shatter on impact when used on a grinder or such. Also, with grinders in particular, the grinding grit likes to embed itself in glass.
I look for LED bulbs with plastic exteriors for this reason.
Marctrees
TX/LA border - Toledo Bend
As mentioned above "Rough Service" is the correct term.
The 130v may have thicker element, but not supported as well as RS... they are made to buy for longer life span... when connected to "120" v.
And, so usually a little less bright also.
Marc
Stuart in MN
Minneapolis
Home Depot has rough service bulbs listed on their website, but nothing under 100 watts. Try a good local hardware store.
markhm
NY
Some "fan light" bulbs are rough service. Check their labels for that.
PhysicsDude
Dallas, TX
I use PAR 20 LED bulbs in my tool fixtures (grinder and drill press). They fit the housing really well and have good light distribution.
Norcal
I do the same but PAR lamps do not work well in a grinder eye shield, for that I think LED's would be ideal.
