Can you identify this Delta table saw
sofasurfer
I have a chance to buy this saw from an ad. I want to know what its worth but I can not identify it specifically. Anyone know any specifics about it and possibly it value? And if that is an after market fence, what is it worth. 10 inch, tilt arbor.
turbowoodworker
Apex NC
That is a pretty nice saw but it looks like it sat in the rain. I think it is a hybrid saw, half way between the contractor and the Unisaw. The fence looks good too. Having said that, what's it worth? How bad do you want it? It is not a Unisaw so it's not that strong but I could see paying $400 maybe if I really needed a hybrid. Let's see what some others say.
R_einan
Eastern WA
Made in the early 90s, it was a model between the contractor series and the Unisaw cabinet saws. Should have a 2hp 220 motor, IIRC. Kinda the precursor to the ‘hybrid’ saws. I would agree with turbo, unless you can get it for 300-400 I would look elsewhere. A used Unisaw can be had for not much more money and is a much better saw.
sofasurfer
I would prefer if I was able to put a 110v motor on it. I am currently using my old circa 1990 Craftsman 10 inch table saw with a Delta rip fence. You think this would be a step up? Can you tell me anything about the fence thats on it?
Thanks for your help.
Voi
Western South Dakota
I believe that's a 36-750. As I recall they did not come with a dual voltage motor. Some of the later Delta hybrids had dual voltage motors so maybe some of the 36-750's did as well.
Google that model # and see if you can find any details to confirm. I'm on my phone on a very slow internet connection so I can't check.
The Cobbler
with 120 volts you are limited to about 1-1/2 hp motor which is medicore, if it's the unisaw type motor, they are specific and have brackets to fit the saw. not a standard base. I don't think you'd find a 120volt unisaw motor . I think they are minimum 3hp .
sofasurfer
Does 3 phase mean 220v? A typical 220v air compressor outlet would do the job as long as the plug matches?
exmaxima1
Midwest
Nice huge fence. Mobile base. Fully enclosed stand. Lots of nice features even if it does not have the massive Unisaw trunnions, cast wings, or multiple belts. If I needed a saw, $250-300 would not be out of the question.
Packard V8
Spokane, WA
Yes, 3-phase is at least 240 volts, when it's not 440 volts. Are you certain it's a 3-phase motor? Those saws were usually single phase.
No a typical compressor/dryer outlet wouldn't do the job. They are single phase.
It would require a rotary phase converter or a VFD to use the 3-phase motor.
jack vines
