Keep
Okay after looking around for new cabinets and not finding what I wanted I decided to build my own. But the thing I am stuck on is the doors.
I do know they will be sliding doors since I do not want to have to worry about keeping the area in front of the cabinets clear so they can open. But I am stuck between using whiteboard or chalkboard. Maybe even one of each. There will be two doors, 1 to cover each cabinet.
Anyway on to the cabinets. They are large, each used just under a full 4x8 sheet of 3/4 plywood. They are 48 inches tall, 16 deep and 34 wide. The shelves are varied in height, 14, 12.5, 11, 8.5. I also used a 1/8 of hardboard for the back. The shelves were, rabbited, dado ed, glued and screwed into the sides. Its overkill but I do not like wobbly things.
I used a double french cleat system to mount them to the walls, then they were screwed into the studs and each other. I grabbed onto the top of them and hung on so I am sure they are not going anywhere. One thing about the french cleats, if your wall is not straight it will certainly let you know! I found out the back wall had a nice vertical seam that made me have to shim the right cabinet 3/8!!
So on to the pics:
Here are the cleats I used:
This gives you a look at the shelf height:
Here they are mounted on the wall, the compressor should give you a sense of the size:
I do plan on painting/sealing them just not sure what color, or I might just use varithane and seal them up.
So on to the pics:
