2ndGearRubber
Currently unhappy with my dial indicator setup. Arm mount is weak, and I'm having less confidence in the repeatability of the gauge.
It will mainly be used for checking rotor run out, so a sturdy mounting system that does not require a flat surface is a huge plus.
I have no issue buying a gauge and mount separately, but I like having a single case with all I need. I can make such a case if necessary. Mainly interested in value, not cost. If it costs 500 so be it, I just need a solid setup I can trust.
Thanks in advance.
Thanks in advance.
