It's a split level ranch.
The way they used to build houses was retarded..
24ft wall right down the middle of the garage.
Also, a little crooked right here and screwed up siding. Shouldn't be too hard to straighten that out.
Any structural engineers or home builders? Do you think it's worth the hassle of removing?
In some ways having 2 spaces can be advantageous. One side for woodworking, another side for car stuff..
But I would still really prefer for one wide open space. I mostly do car/engine work anyways.
I'm by no means an engineer, but have familiarized myself with basic framing and have a plan of attack for how to remove the wall.
1: Rip off all the drywall.
2: Put up a temporary 2X4 wall right next to the existing wall. It will have to go on the left side - since the HVAC ducts are in the way on the right side. The studs for the temp wall will be placed directly under the joists, within probably 6-10 inches or so of the old wall. This will make the work area kinda tight for removal of the old studs, and placement of new header, but I can get it done.
3: Build a header of 2 or 3 2X12s. Is 2 enough? Add the 3rd for good measure?? Or do I need a steel beam or glu-lam beam? I plan on 4 (maybe even 5) column supports for the header.
4: I do not believe there is a footer in the middle of the foundation. Of course in new construction, there is a beam down the middle of the house instead of a full wall, so there is also a footer. With a full wall like this, I'm guessing there isn't a footer. No idea though.
Instead of digging up the foundation to build a concrete footer for each lally column - I'm wondering if I can put down a sheet of steel under each column to spread the load across the floor. Figure something around 3/8-1/2 thick over about 12"-15" would work. Would create a bit of a trip hazard.. but I can live with that, and probably work out a way to hide it. Maybe even box in the lally columns eventually.
5: Put up the lally columns. With 2-3 2X12's over a span of 24 ft, I figure 4 lally columns should support the load pretty well. On on each end, the 2 others spaced evenly apart. I have some lally columns laying around, so that's basically free. Perhaps I could go with a steel or glu-lam beam and only need 3 columns..but I can live with a couple columns in my way. Anything is better than the way it is now.
As mentioned in point #4, each column will be on a sheet of steal to spread the load over the concrete floor. I'll attach the column through the steal plate to the concrete using anchor bolts.
Any critiquing to my plan? I'm a little nervous to get started since it's a fairly big undertaking. The last thing I want to do is weaken the structural integrity of this house. It's a pretty solid structure. Joists are 2X10. Not much bounce in the upstairs, etc.. So I'd much rather over engineer it.
