garagelogician
I have a smallish 3 car garage (about 27-ft wide x 19-ft deep), I would love to add onto it to provide more space for workbenches/cabinets/etc and to add a little more breathing room to make the 3rd stall more functional. I can't extend out the front, because it is already at the front setback line. The house is behind (and about 5 feet of the upstairs extends over it), so I can only extend about 4-ft on the right side, and behind the 3rd stall about 6-ft.
I don't know much about the framing above the garage (all sheetrocked and no access hole). I assume they are trusses. Roof pitch is 6/12, and I'm in MN so we have snow loads to deal with. There is a girder truss that transfers the load of the upstairs bedrooms to a spread footing at the current side garage wall. Without some further engineering, I'm assuming I'm going to have to keep a post in this location (which shouldn't be a deal breaker for how I am going to use the space).
Current ceilings are about 10'-5", and I won't need that headroom in the addition, so keeping the current roof pitch is okay. Problem with that is that I need a 4/12 pitch on the addition out the rear of the garage, to keep it below an upstairs window. Any thoughts about transitioning the roof pitch?
I know next to nothing about home construction or framing, but does this seem doable? Any ideas on what I should request from a contractor?
Lot cert with proposed footprint:
Existing front elevation:
Modified front elevation with 6/12 roof:
Modified front elevation with 4/12 roof:
Side and rear elevations:
Existing foundation plan:
Existing framing plan:
Section view through house/garage/foundation:
Picture of the front of the house when we moved in 2.5 years ago
