7/16 or 1/2 osb
ezover
3rd rock from the sun
what are your thoughts on osb thickness for the ceiling and walls?
my thoughts were 7/16 for the ceiling and 1/2 for the walls.
i can't think of any benefits in doing the ceiling with 1/2 inch osb at 2.50 more per sheet.
PassnThru
Bowling Green KY
I haven't even seen 1/2" OSB in a long time - 7/16" only. My garage ceiling and walls are 7/16" and it hasn't been a problem. I don't think 1/16" is going to make any real difference.
Gary S
Bismarck, ND
When I built my garage a few years ago, I bought 7/16 for the roof and outside walls. A couple of years later when I finished the interior, I bought 1/2 because I found it on sale cheaper than the 7/16.
It really doesn't make any difference. 7/16 meets code for structures around here, but if 1/2 is cheaper, get it.
cookster
Don't allow OSB on ceiling here. Did all my interior walls with it. Now have go over one wall by house with fire rated dry wall. :lol_hitti
PassnThru
Bowling Green KY
....how much is OSB your side, out of curiousity ?
We use truckloads of 15mm at USD$4.76/m2 (call it a yard..)
Haven't priced it lately but normally a 4X8 sheet of 7/16 is around 5 - 6 dollars. I have seen it above $10 after a major hurricane strike here when all lumber prices go up. It's actually very competitive price-wise with drywall here. So, that's 32 square feet compared to a square meter? Converting with Google I get 1 square meter is equal to 10.76 square feet (which is a little larger than a square yard). A 4X8 sheet is 32 square feet. I think you are paying more which is pretty much to be expected.
srmofo
SW ohio
I just built my garage (unattached) in october with 7/16 for 4.79 a sheet. Just did a quick price check and its jumped to $6.27 . Looks like 1/2 has droped about .50 down to $7.77
Could the earthquake have caused this sudden spike? It was still 4.79 in the first week of january
PassnThru
Bowling Green KY
I wouldn't be surprised even though I don't think much OSB will be used in rebuilding Haiti. Probably like gas prices - any excuse to raise the price. It will probably settle back down in a few weeks.
nate379
Palmer, AK
I had to argue with the manager at Lowe's yesterday about 1/2" OSB!
I needed 1/2" to shim something flush. They only had 3/8, 7/16", 19/32" and 21/32" He claimed all "matter of factly" there is no such thing as 1/2" OSB.
I was like... hmmm... maybe I should call my Dad to let them know then. Better tell him to shut down the line making 1/2" OSB :bounce: (He has been working at an OSB mill for almost 30 years. )
I have no idea where those funky sizes come from but normal OSB sizes are 1/4", 3/8", 7/16", 1/2", 5/8", 3/4" and 1 1/8"
As for the prices, here 3/8" is $10, 7/16" is $16
94legaleagle
my shop CEILING AND WALLS are finished in 7/16 OSB - have been that way for 21 years or so with NO problems -
IMHO, use whichever one is cheaper
they DO make 1/2 inch OSB - I've used it for roofing a little
BackAgain
It's up to about $7.25 today at HD, from $5-something just a few weeks ago. I wish I would have bought a load, damnit! It's been rising since before the earthquake, I'm not sure why this time of year though?
Kevin54
MEMBER EMERITUS
Urbana, Ohio
Around my area it depends on where you get it for what they use. A lot of contractors went to using 7/16" for walls and roofs while others will still use 1/2" for roofs. Personally I don't like either. I have 1/2" on my roof and depending on the temperature outside, and attic temperature, you can see where every joist is.
As far as pricing, the 7'16" was down to around $5.79 / sht. the last I looked but that has been a couple of months now. The price of it will fluctuate more than other dimensional lumber. If the building picks back up here in a couple months, it will probably hit $9+ a sheet for a while.
Torque1st
MEMBER EMERITUS
KC Metro, Kansas
15MM would be that 19/32" stuff.
17MM would be that 21/32" stuff.
Many sheet goods are metric now. It all depends on the supplier.
The OSB price will also fluctuate with oil prices.
Brad1234
I have 7/16 on the ceiling & walls in 2 garages & it is plenty sturdy. If your wall studs are more than 16" on center I would do some experimenting because I think that you would get alot of flex if you push on the wall.
