Loosening knot on tow strap
HoosierMark
Southeast IN
I used a tow strap to pull out my bobcat last week. I simply used the loop and fed the strap thru it. Now it is really tight. Anybody know any tricks to loosen it so I can separate the long tow strap from the short one? I know I should not have done it this way but the cost to get the right hookup was a lot greater then the cost of the strap. I was twelve miles away from my tow strap bag so sacrificing the straps if it comes to that was cheaper.
So any tricks to get it loose?
EOC_Jason
Bentonville, AR
Screwdriver and a lot of patience... Sometimes if you can push some of the strap back in it will loosen enough to get the screwdriver started in there and then you can work the loop larger.
Voi
Western South Dakota
I've used both hot water & the hammer trick to get knots out of tow ropes on boats. Not sure how that will work on a tow strap.
Kaizen
New England
Good luck I ended up cutting mine after fighting with it for an hour
H
HoosierMark
Southeast IN
Just found out I am headed to Florida via Alabama in the morning for a week so it will be next weekend before I can test out the advice. Wish I was headed there in a few weeks but not my call. Oh well, we should be near Daytona Beach Sunday and then headed west. Hopefully the storm will visit Indiana while I am down there. After 5 plus inches of rain last weekend, I do not care for more.
u3b3rg33k
I usually twist the tail tight and feed it back in. also I try to use climbing knots that are intended for load - not sure what you tied.
Kev442
Wi
Buddies tree felling rope had a knot he found after yanking the tree that was hung up. I watched him dink around. Told him to get a flat bladed screwdriver. He dinked around using pliers. Finally got a screwdriver. 2 minutes, tops. Rubber mallet sounds interesting, I'll use that in conjunction next time.
H
HoosierMark
Southeast IN
It is a strap with a loop on each end about 20 feet long. it was attached to a second heavier strap about 5 foot long which also has two loops. Not sure why we used two straps but we did. Took the long strap and ran its loop thru the short strap loop and then pulled the long strap thru it's own loop. Pulled it with a 95 horse power tractor to recover the bobcat. Bought the straps at Menards or HF. I doubt if I paid much for either one. (Look up the word cheap in the dictionary and you will see my picture ha ha) I figure to give a try and then I probably just end up with a longer tow strap but if I can get it loose, I would like that.
Firebrick43
West central Indiana
We use synthetic slings and straps at work. All manufactures will tell you a sythetic strap that has been knotted and a load applied is now junk and should not be used again. Even the new high strength ropes can not be knotted and have specific splices to form loops.
rlitman
Long Island
That's a good tip, I'll have to remember that if I ever do end up having to join two together.
Agreed. In the comments, someone recommends using a flip flop for the same purpose. Anything both soft and tough enough to work that won't turn into a missile should suit the purpose.
Worsedog
Central FL
Another endorsement of the hammer. Works great on tow straps, ratchet straps, and rope. You don't have to beat the **** out of it either, tap, turn, tap, turn.
bad_idea
Pasquotank, NC
Hammer. In the shipyard we use flat strapping and tie square knots into it to whatever length we need a sling. After hanging couple thousand pounds off it the square knot cinches up tight. Smack it with a hammer, push the two ends towards each other, repeat. Haven't met a knot yet I can't get loose with a hammer. Well, a quality knot. Granny knots, thats a different story.
theoldwizard1
SE MI
EVOLVO
Port Hadlock, Wa
If you join them properly you'll never have a problem:
<iframe width="560" height="315" src="https://www.youtube.com/embed/f5BMbExC6kU" frameborder="0" allow="autoplay; encrypted-media" allowfullscreen></iframe>
rsanter
visalia ca
Get a screwdriver or punch through the know and try to work it loose.
By hand will get you almost nowhere
77Birdman
North Eastern MD
Good Luck! I had one of those one time, never did get it apart. Tried most of the above methods. I know for safety it should be thrown away but in the real world not everyone has a couple hundred bucks laying around. I ended up using the one I had as a tow strap when needed. Never in a situation where failure would end up in disaster.
