Cutting a sheet of ABS plastic
Rocket1
Arlington, TX
I have a sheet of ABS plastic that I need to cut. Its about 3/8" thick. My plan was to use a dremel and cutoff wheel but thought I would check for other suggestions.
Finish isn't the biggest concern for the current project but might matter on future projects.
Moose-LandTran
The Brink of Insanity (England)
Don't do that! I almost lost a thumb doing a similar thing.
Use a fine tooth veneer or wood saw. Or a heavy-duty scriber, which would take a lot of passes to cut through 3/8" sheet.
wendell
Boston
Band saw, jig saw, scroll saw. Anything that "cuts". You don't want to abrade the plastic because it will melt and gum up.
mkdive
NPB (Socal)
eborcim
Central, MO
How are you cutting it? Straight line or shaped? Straight line get a plastic cutting blade for a table saw or circular saw, they clean out faster and don't melt the plastic as much. Shaped line use a big-*** bandsaw, scroll saw, airbody saw, or jigsaw.
Mickey_D
Austin, TX
I have cut a lot of it with my Fesstool saw with the blade speed turned down low and it does great. Keep a good steady pressure (cut faster than you would on wood) so you don't burn/melt it. You can even rub the sides of your blade with blade lube or even wax and that will help with the appearance.
Tool Pants
San Jose CA
ABS is that black plastic used for plumbing, correct. If so, I once made a small box out of sheet ABS. I used my chop saw with a carbide blade wood cutting blade. I may have also used my table saw. If you need to clean up the edges use a file. Easy to cut. Then I glued the box together with the black cement that is used for ABS plumbing fittings.
R
Rocket1
Arlington, TX
Yes ABS is used in plumbing. I am using the sheet to reinforce a interior panel. I bought some ABS Cement that is used in plumbing to experiment with. I'm hoping it will make a permanent bond that will not separate and not damage the visible side of the panel. I've tried fiberglass but the resin didn't bond like I thought.
To answer the other questions... It will be a Straight cut.
I do not have a table saw or a band saw that I can use so I'm limited. I do have a circular saw though.
Diablo
I sometimes have to cut those plastic lenses for flourescent lights, i find a 100 tooth 10 inch table saw blade installed backwards in my table saw works the best.
DHCrocks
Hawaii
for straight cuts score it with a utility knife on one side and bend it it'll snap with a clean edge.
BlindViper
York, PA
If circular saw will work however there is a risk of the saw binding and grabbing. I a jigsaw would be my first choice. If the cut is small use a handsaw.
Thedroid
New Mexico
I made many a machine guard out of different plastics. A Jigsaw is your best bet. I actually like a blade somewhere in between, as the super fine tooth can take forever to cut.
mooman
CHICAGO, IL
Perfect reason to go out and buy yourself a good, variable speed jigsaw!!
kerryt1
Oklahoma
Rotary cutting tool will make a messy cut. Bandsaw or jigsaw. I bought a B&D jigsaw for like $40 I think.
84scrambler
Livermore Ca.
a finish blade from a circular saw will be your easiest and best finish at least for acrylic it was. I never tried cutting ABS sheets like this but have lots of experience cutting acrylic sheet for fish tanks. If the piece is over sized try doing a practice cut and if it doesn't cut well you can always resort to a jigsaw.
I have never had any real luck with jigsaws, the blades walk all over the place and leave a horrible finish. Usually when your building sumps for fish tanks you would make your primary cuts on a table saw and do a final finish pass with a router. This combination gives you a good finished edge capable of creating a water tight seal when glued together.
A skil saw is just a portable version of a table saw. Clamp a level to the Sheet of plastic for a straight edge and run the saw at a constant speed to get your cut.
BlindViper
York, PA
The quality of the jigsaw and the blades plus the user make the cut straight.
R
Rocket1
Arlington, TX
I found my jigsaw and was able to cut the plastic sheet. Worked out pretty well too. I ended up needing a smaller piece so I scored the plastic using a straight edge and a sharp utility knife. I had to score it several times but it worked very well.
Now if I could figure out just how to get the piece to bond to the panel I would be set. The cement I bought just doesn't want to bond to the panel. I've tried several methods but it hasn't worked. It's almost like the panel is too slick... I sanded the panel with 60 grit sand paper and tried again. I hope it works this time.
R
Rocket1
Arlington, TX
I think I found what your talking about... Looks to be a crafts glue.
I think the ABS cement should work though. The other things I might try are acetone or some MEK to melt the two parts together. I've been able to experiment on a junk panel so that's helped a lot.
BlindViper
York, PA
yup way to read the thread and give a solution to a already solved year and a half old problem.....
DHCrocks
Hawaii
well since it's back from the dead....
I just used this this past weekend
it worked great on intricate cuts, if you need an inside corner or a curve this is the tool to use, much easier and cleaner then a jigsaw.
fitz11
Fox Valley, WI
The best way I have found is one of the oscillating tools made famous by fein and now copied by many others! I have a cheap harbor freight one it was only about $30 and it is awesome just use a straightedge and the half-moon cutter it comes with. This method works wonders with plexiglass too!
Jack Olsen
Los Angeles
For a straight cut, a circular saw and a fine cut blade (many teeth, not few) should be okay. Use a straight edge and score it first with a razor. A jig saw would also work.
A dremel or circular saw is going to be a nightmare for that. It gets hot and globby. It's also prone to cracking, especially as it ages. Even worse with UV.
Bigbandguy
North Carolina
I found this thread through an outside Google search for suggestions on cutting ABS for a project I am looking at. This very old thread solved a problem for me so thanks guys. No thread is out of date if it contains the information you were looking for. Who know, by bringing it back from the dead again somebody might come up with even more ideas !
