corrosion resistant chain for sliding gate?
Vintage Veloce
San Diego
The chain for my sliding gate is getting darn ugly. I've heard of nickel plated and stainless steel chains. Looks like the Stainless stuff is expensive, but the Nickel plated ones might not be too bad.
Does anyone have a recommendation?
(And please don't tell me to oil the darn thing regularly! ;-)
It takes 27 feet of #41 chain.
rlitman
Long Island
My Old Tools
Hamrick Lake, TX
Our community gate has been up probably 20 years. I oiled it up this winter, probably for the first time. Plain old chain, still going strong. Your salt water environment is harder, so your mileage may vary.
Worsedog
Central FL
Some stainless would be $150 from Amazon. If it were me, which of course it's you, I'd throw down just to avoid effing with it.
kbs2244
Check out the industrial parts sites
This is not a new need.
Millwrong
Canada
San Diego? Is your chain on the brink of failure, or simply "getting ugly"? 27' of stainless roller chain should be chump change for someone who gives a **** what their gate chain looks like!
V
Vintage Veloce
San Diego
Yeah, I know, it's a small thing. But our yard is nice and the crusty chain dangling across it for about 25 feet is the ugliest thing in sight.
And there are the stains it leaves on my white pants. ;-)
But the question... does anyone know if the nickel chains are pretty good corrosion wise? They are half the price of the stainless ones.
mcbane
California
"But the question... does anyone know if the nickel chains are pretty good corrosion wise?"
Once you scratch the nickel plating, the steel under the plating will form a galvanic cell with the nickel plating near the scratch and will use your salt water as an electrolyte. The steel will be corroded rather than the nickel plating (opposite of how galvanizing works). The voluminous corrosion products formed under the plating will cause the plating to blister off. IMHO, rusted steel looks better than blistered plating so I would opt for un-plated steel chain rather than plated.
heffneil
Naples FL
I replaced the three chains on my gate - myself- to stainless years and years ago. It is softer but I will tell you the salt water and all the regular chain just couldn't hold up. It was a better investment than replacing the chain every year which you could do. I have to remove a couple links a year and tighten every 6 months. I took one of those Dewalt carry totes and loaded it up with chain tools and labeled it as such. What I can't find is the gate bolt that is stainless. I usually just remove the old one and put a new one up. They are cheap - just a hassle to replace it. I've thought about using a threaded stainless rod and bash it down and drill a hole - just never did it!
kingchevy
Chain looks like **** just hanging, take a piece of 1 1/2" channel and make a chain tray for it.
V
Vintage Veloce
San Diego
Here is the new Nickel Plated chain.
$60 for 30 feet, with master links, on eBay.
We will see how it holds up.
V
Vintage Veloce
San Diego
Well, here is an 18 month follow up.
The cheap eBay nickel plated chain has worked fine, but it's covered with gunk, so you would never know it is nickel anyway!
It does seem to be well preserved under the gunk.
So, I guess having a "pretty and clean" chain is impossible, unless you want to clean the thing, and I'm never going to go that.
kbs2244
I would have suggested an industrial oiler and motorcycle chain oil.
it may sill clean up your current install
manwithtools
Lebanon, TN
Where in San Diego? That looks like fine desert sand that has found its way to your oiled chain. If you are in the desert area, that's going to be a constant battle. You will need to clean and re-oil once a year or so.
V
Vintage Veloce
San Diego
LoL. I'm an avid motorcyclist. The chains on my motorcycle are well maintained. The fence? Not cleaning and oiling that thing. ;-)
I wiped a single link, and it looks fine under the crud.
PFSard
Mesa, AZ
I don't know if this is a plausible solution, but ....
- I used to lube my bicycle chains with various types of lube. Pain in the **** to clean chain and re-lube with the dust/dirt around here.
- Now I pop the chain off once a month, quickly wipe it down with a rag and drop into melted paraffin wax. I average 1-1/2 hours riding per day. None of that dirt collects on anything anymore. Chains last as long as with other chain lubes.
steaks&anvils
Colorado
crud - environmental friendly protective layer. Like when the elephants roll in the dust, elephants know best.
couch67
Ontario Canada
Not to be picky but that was your 30 month follow up
nadogail
Coronado, CA
Chain Drive and White Pants is a disaster waiting to happen. Stand well clear of an exposed lubricated chain while wearing anything White.
