main sewer line ???
camaro77
rhode island
got to cut out a main P trap in my house for the main sewer line and I plan on using PVC in place of the cast trap. I have a 4 inch cast main vent on the house side of the trap now my question is does the vent need to go back the plumbing is all new and updated in the house with traps on all the sinks and tubs and toilets and a vent all the way up to the roof. also can I use just sch 40 white PVC or does it need to be the green sewer PVC? this will be getting back filled and buried once the job is completed.
Thanks Jeff
The FIB
chicagoland
I would think local codes would decide what would be acceptable, I never heard of a P-trap on the main sewer line. The cast Iron is really heavy stuff, make sure it is well supported when cutting anything in the house. I heard a story of a guy who cut a section out in his basement pipe causing the riser to drop a little, causing nearly every joint in the system to leak.
SALIV8
chicago and s/w michigan
Also never heard of a main sewer line Ptrap, but if it were me I would replace what is there with a min of sch 80 pvc if it's currently cast.
Disclosure- I am not a licensed plumber.
75gmck25
Alexandria, VA
There are different types of Fernco couplings, and the one you want has the rubber to seal against the pipe, and a wide metal band to compress around the cast iron and PVC pipe and provide support. Once you get it in place and tight, you then want to support the pipe joint from underneath with something that will not compress and let the joint move when you pour cement on top.
I just used some bricks and sand under the joint, but some folks recommended pouring dry cement mix in around the pipes and then pouring water on it to form a bridge/support. I'm not sure if that would work better.
Bruce
Jim greengo
Behind my house
Bruce
no nub coupling.
tfb
Eastern PA
If you are talking about the curb trap, the vents on these are usually sealed now because your municipality does not want to treat storm water which can enter the sanitary system thru the vent.
However it isn't a bad idea to install the vent because it give you a great access point to clear a blockage from outside the building. Plus it allows you to assess exactly where a blockage is located.
It creates a water seal, (trap) between the main sewer and your house drain and prevents travel from the main to your lateral line.
https://www.beatlas.com/details/1600SV412
6768rogues
Western NY
It sounds as though you are talking about a whole house trap. They are typically not used in our part of the country, but I have seen one occasionally. In codes that recognize them, they do need a fresh air inlet upstream of the trap but close to the trap. That vent usually just goes through the wall higher than the trap to outdoors, not all the way up through the roof. If your local code no longer requires the trap, simply eliminate it.
Schedule 40 PVC will do a great job.
kbs2244
Get rid of it.
Any sewer gas will vent through the house and out your roof.
GTO
NJ,FL
Years ago(long time ago) before they required traps under every sink and tub/shower,they put the traps in the main line..
Very common in older areas.Very old
