Who's a wood burning stove expert?
Webbie1
Not in a garage, but basement of a house I'm considering buying. I'm a sucker for wood burning stoves. What can anyone tell me about this one? Obviously put into what used to be a fireplace. The house was built in the 50's....not sure the age of the stove, but to me it looks pretty cool. What can anyone tell me about this one? I took a screen capture from a video I made when I looked at the house, so this is about the best image that I can capture from that.
Thanks in advance,
Warner
https://drive.google.com/file/d/1aYRXeC4UknGVCE6E-4LmHSdW4j1DYQcK/view?usp=sharing
larry_g
oregon
That looks to be an old Fisher type stove from the '70s. It is vented into what looks to be a fireplace. May or may not be legal these days as running a stove into a fireplace is some cases is a fire hazard unless the stove is removed to clean out create annually. Is this on the west coast somewhere?
lg
no neat sig line
W
Webbie1
lg
no neat sig line
Nope....in the Rockford, Illinois area. Thanks for the reply....going to look up Fisher type stoves now...
Warner
xjfish
I grew up feeding the same wood stove in the upstairs of my parents home. Sadly they no longer own the home but I'm betting that wood stove is still there and fully functional. I do believe it is a Fisher. Awesome stove. Heated well over 1,000 sq. feat easily. Well made heavy stove with squirrels on the front. The only complaint may be that the firebox could be bigger? I'm just going on memory here. Good quality! If you have any specific questions I can try to answer.
W
Webbie1
Thanks! Someone on another forum doesn't think it's a Fisher. I really don't care who made it, as long as it's quality, functional, and safe to use. I appreciate all the knowledgeable helpful guys (and gals) on here.
Warner
xjfish
Warner
:) I should really know this! (Brand) It is bugging me now. If I get a chance I will ask my old man, I'm sure he will remember. Will post if I find out for sure.
u3b3rg33k
xjfisjh, i'm in the same boat.
I'm not familiar with that model, but for the past 25+ years we've had wood stoves. first was a Vermont castings insert (catalyst model), more recently a Jotul. both we did a stainless liner/cap for a better draft and no creosote issues. we burn 10 or so cords per year on average.
I very much prefer the simpler setup of the Jotul with secondary air vs the interior complexity of the VC (baffles + catalyst + damper + fans). ended up making stainless parts for the former because when you heat solely with a wood stove, the weaknesses reveal themselves.
NUTTSGT
Northern Central Ohio
You know the way their stoves have lasted, this may be a design feature. Keeping a smaller firebox might prevent people from over firing the stove and causing damage and failures.
Jazz1
Thunder Bay On.
Newer wood stoves are much more efficient. I see stoves like that at the scrapyard because insurance companies won't cover them. Not that there's anything wrong with them other than being out dated. You should go to a shop that sells wood stoves and enlighten yourself. I have a Pacific Energy wood stove. Excellent and efficient.
W
Webbie1
I have no doubt that the newer ones are more efficient. This one is already in the house, so I would use what's there. If you get your wood for free (and anyone who puts a little effort into that, at least in my area, can), then the efficiency is a lot less of an issue.
If anyone figures out the make and model, I'd appreciate knowing. Thanks to everyone who has responded so far....much appreciated!
Warner
tyme2par4
NH
It should be vented all the way up to the top of the chimney with a stainless steel liner.
You also want to make sure there is a cap on the chimney that is well sealed, or that is just a highway for the hot air to escape.
W
Webbie1
If you buy the place I'd at least pull out the wood stove and clean the chimney/liner? This will allow you to see how its connect into the chimney.
Good suggestions guys. If I buy it, I'll keep everyone posted.
Warner
larry_g
oregon
The reason I asked your location was that in this area a lot of stove company's popped up when the fuel crisis happen in the '70s and and lasted only a few years till the EPA got involved. My folks had a fireplace conversion done like that and the connection to the fireplace looked like that and just vented into the firebox without any connection or liner to the chimney. It caused problems and near burned down the house. I would recommend that you have the whole thing inspected to see what is there and if the chimney is still good. You won't know till the stove is moved and things looked at.
It wasn't till many years later that it became mandatory to line the chimney preventing all the problems that some of the earlier conversions were discovered. If that stove dates to the earlier years it could be a problem. Look for a tag on the stove giving information. If no tag then it is an earlier one.
lg
no neat sig line
W
Webbie1
lg
no neat sig line
Good info, guys. Thanks. I'm looking at a few different houses so no telling where I'll end up.
Warner
TractorJeff
Elkhorn, WI
What post 18 says!
When they direct vented into the fireplace there is lots of creosote build up on the walls and up the over sized chimney. Remember the chimney is sized for a fireplace. Anyways the creosote catches fire then super heats the liner and brick/block chimney. By the time the fire dept shows up the damage is done!
When we bought our house 20 years ago, I used this as a bargaining tool by insisting a chimney inspection be done. Guy came in, pulled the stove and said yes its currently an illegal setup. Got a couple grand knocked off the asking price!
After we bought, I had it direct vented into the chimney which is the next safest set up for the time period which still requires an annual cleaning. We ran that 24/7 to keep the chimney hot to minimize creosote build up but it still builds at the top working its way down. After 10 years we were able to afford having the chimney stainless steel lined to the correct diameter for the Stove.
If you decide to buy is make sure it is UL certified because that is an Insurance company requirement. Next hard part is finding an Insurance company that will cover wood stoves. Mine gave a slight discount on the Premium because we had a second Inspection and he certified it to be legal and safe.
W
Webbie1
What post 18 says!
More good info. Thanks!
Warner
biggziff
Upstate NY
No matter what you do, pay a local chimney sweep to perform a level II chimney inspection before you put a fire in it.
Bretny
Dutchess county NY
Theres really not much to go wrong with old wood stoves becids the seals. There easy and cheap to change. They really are just a metal box you build a fire in. Chimneys are a whole other thing more concerning than the actual stove.
The problem i see with that one is it appears to look like the distance betwen the floor and chimney inlet looks low. This can really limit you on what other stoves you can put in there.
yeldogt
Chimneys need to be part of a proper pre check ... they need to be inspected. Post #18 is spot on .... most of the early inserts don't have liners. They use the existing chimney flue -- those inserts were everywhere in the 70's. Most fireplaces were for looks ... very few built in the 20th century were for heat .. you could overpower the flue.
Mustang415
I have a stove in the shop and an insert in the house. The insurance company made me jump through hoops for the one in my garage but couldn’t care less about the one in the house.
