I've got an Emerson Sensi for our house. Just a basic thermostat that you can also control from you phone.
Thanks for the replies, the directions aren’t too clear and I’m not sure if it has a C wire or not. I was hoping somebody had one and could tell me which thermostat they were using. I haven’t installed it yet and was looking to have everything here before tackling the project.
Cant go wrong with anything Honeywell. Ive heard good things about Ecobee as well. I install Honeywell exclusively. Stay away from Nest. Its garbage.
Just what I need. If the gas company needs money, they can hack into my WiFi thermostat and turn up the heat.
I use the Lux one with my Beacon morris heater just fine. Similar to the hot dog. I chose this one because I can adjust the temperature swing +-2 degrees to keep it from short cycling and have it not running as much. Most of the others you have no control of this. It works really well for me. It also appears to be a lot cheaper too at $97 right now on amazon.
https://www.amazon.com/dp/B010PTKWW6/?tag=atomicindus08-20
Does anyone know the minimum working temperature on this particular LUX t-stat or any other wi-fi thermostats listed in this thread? My home one is 45*, I would prefer one capable of going lower for the garage. Couldn't find this info for the LUX.
