moparfreak
So I've got an interesting little project coming up.
When I built my shop onto what was an existing 2-car attached garage, I structured the area above the new shop to serve as an attic. I put OSB sheeting up there to serve as floorboards and it's been real useful to have this attic space for all kinds of things. The one challenge has been that the area that is above the original 2-car garage (still part of the shop) is very difficult to access. This is because the original roof rafters of the house (a hip roof style in that area) allow for only 16" between centers, so putting materials through that opening is difficult, not to mention for me to crawl and squeeze in there also.
Now that I am getting ready to do a full restoration of my Charger, I want to use the attic as a space to put parts from the car as I pull them off so that the main shop doesn't get overrun.
I need to make a pathway, and I'm wondering, from a framing perspective, what's the best way to patch in an opening? If I cut out these two rafters will it cause issues with the original ridge of the house? I can probably do some sort of boxed in frame to get the load from the cut-out rafters transferred over to the outside ones.
Here's a picture to help explain (sorry about the junk blocking some of it). The red line is the pass-through opening I'd like to create. The yellow arrows point to areas that I could sawzall out and then try to reinforce the opening.
ALso, to help understand from an aerial view, this is the attic space as shown on the plans for the shop remodel. THe red lines are approximately the rafters I want to cut out:
If I cut those rafters out partially to make the passthrough, will it weaken any other part of the structure overall? I can't imagine it really would, since there's so much other framing tying the ridges together. Just want to make sure my thinking on this isn't way off base before I start hacking things up...
