kasander
HVAC pros,
I am installing a Goodman HVAC system in my garage apartment and need help with the drainage requirements. The air handler has a primary and secondary drain on it. Am I required to also have a drain pan under the air handler? If so, how do I accomplish this with the unit in the downflow configuration? The air handler will be in a closet, and the duct will exit the bottom of the air handler and go straight down under the floor into the trusses. Am I required to put a drain pan with a square hole in the middle for the duct to go through? Or are the primary and secondary drain lines on the handler enough to satisfy code?
I am using the Goodman ARUF25B14 air handler and GSZ140181 heat pump.
The pictures show the approximate installation location. I am guessing I should build a stand to put the unit on top of so I can easily attach the duct to the bottom side of the air handler. Any help is appreciated.
