jproaster
This stuff is certainly basic to some of you...but not me.
Since I can't find certain fittings in town; gonna order online.
So. I thought I'd run by you what should be the last parts needed.
1. At the rubber hose exiting the ball valve at ac, I need a 3/4" fitting (reducing adapter?) to 1/2" fnpt (hose end).
2. End of runs (2, maybe 3) for tools, etc.- air filter then regulator.
A. 3/4 fitting reduces to 1/2 mnpt attaching to air filter;
B. exit filter with a 1/2" straight connector to female of regulator;
C. exit regulator 1/2" mnpt adapter to 1/2" copper pipe;
D. short section of 1/2" copper separating regulator from couplers:
E. 1/2" copper pipe adapter to 1/4" mnpt to couplers.
So. I don't know the proper fitting names etc. and I'm not sure if I've described well. Thanks for any clarifications.
Thinking I would order the fittings from Zoro. Good?
John
*I have the pipe, 90s, T, ball valves for other aspects of the build.
John
