Enclosing electric meter
Shocker
Olympia, WA
So I am going to enclose my lean to carport, but the electric meter is in an area that would be enclosed inside the new woodshop space.
It is a smart meter and doesn't require any reading.
Anyone see a problem with doing this or has anyone done it?
Charles (in GA)
50 mi south of Atlanta
Check with the Power Company, its their call. I think those meters are IR and thus are line of sight (I could be all wrong). In any case, I would think the POCO would still want to retain the right to visually read the meter in person if needed.
Charles
dugger10
Yeah check with the local power company. I work for one in Texas and were installing smart meters right now. They may let you but they'll want access 24-7. Most likely they wont let you, we don't and will cut power off if meter gets covered, smart meter or not. No sense in trying to fight them either, its in the aggreement you sign for service and its law they have access. There may also be a Fire code dealing with this too, the Fire Dept. needs access in case of a fire. Don't want fireman fighting fire in a house with the elcetricty still hot. Good luck.
Grumpy365
Brazoria County Texas
Centerpoint (here in the Houston area) definently requires they have access to the meter. (I just went through this, I evene had all the require permits already approves, and Centerpoint still wouldn't budge)
holland_patrick
hartford ct
Sorry but us firemen are told not to pull meters any more... way to dangerous...
BackAgain
I think the smart meters they just installed out here use the old pager network to call home. They can turn off your power remotely, much farther than IR can travel.
Stuart in MN
Minneapolis
Assuming you're served by Puget Sound Energy, the answer is in their handbook on page 3: http://www.pse.com/SiteCollectionDocuments/builders/1218.pdf
You are required to install your meter socket in a place that is accessible to PSE. All locations are subject to approval by a PSE Representative. If you have questions regarding meter locations, call your CCS Representative at 1‐888‐321‐7779.
Meter sockets, including CT enclosures, must be located:
- Outside.
- On the front 1/3 of your home closest to normal public access.
- In an area that is not subject to being fenced‐in (patios, decks, porches, breezeways and backyards are bad locations).
- On a structure that is owned by you.
Shocker
Olympia, WA
- Outside.
**** a$$ ****. I did call PSE and they were vague on the matter. They said they preferred it to be accessible etc. Now I see it in writing. Cuts over 3' off my woodshop. Dammit.
Thanks Stuart and everyone else.
VDubJoe
New Port Richey , Fl
I am a troubleman for PEF here. Closed in works great till i have to ck voltage if you have an outage. Even with some of our remote voltage ck ones i still have to go out because we cannot get ahold of the customer and it still needs to be checked, We encounter them all the time and what a pain. We have smart mtrs here to. And they fail pretty regularly. We have started now going thru the channel's to have the customers relocated them. So i would advise against it.
Shocker
Olympia, WA
I agree. Nate, I was thinking about that, but I think it would be too much hassle and expense.
I will just have to live with it.
airbassador
You're going to have to relocate the meter. A year or so down the road and you won't even remember having to pay to get it done, and you'll be enjoying your enclosed carport.
NUTTSGT
Northern Central Ohio
We will pull the meter if we absolutely have to, main breaker arc welds open, or a well involved house fire present ing the danger of water entering the braeaker box or exposed wiring. . . . not all breaker boxes have covers on them.
brownbagg
have them pull the meter, change the box into a sub panel and move the meter outside the garage. half a day work
