What's on your walls? Neat storage ideas!
JonnyC
Green Bay, WI
That's really nice. I don't weld, so I wimped out and bought a prefab version:
I used to have it mounted on my bench leg, but it kind if got in the way so I attached two heavy duty magnets to it and now I stick it on the side of my storage cabinet when the torch is not in use and then bring it out and stick it on the floor cabinets when I'm using it.
Tommy
Thanks for this! I noticed they have them at Mendards, so I'll pick up one for my garage and one for my basement.
Project_shadow
Ditto! :bowdown:
I keep shuffling my Race Ramps around on the floor not thinking how I could store them more efficiently. Love this idea. [emoji481]
Mine unfortunately are metal, and a bit twisted, they reside in the project truck bed as of recently lol
Sent from my SM-N950U using Tapatalk
Bessy
Ontario, Canada
Hey Bessy, is that a suburban in in your avatar ?
Nice vintage mower !
Sorry, I missed this post before. Yes, Farleyfan, it's a 1971 Suburban 12hp. Bought it in 2008, with a 42" dozer blade and 42" mower deck. It's been repainted since, (went orange this time, close-ish to the 68/69 paint scheme) and I'm awaiting a new fuel pump to come in as the walbro autopulse leaks and has ruined some of the paint on the front end. Hoping to have it back up and running in time for 2071 lol...5aa8b98212ee159b53f6a21c62169838.jpgcc622b9b904bcb656ec47cf6453dd39c.jpg
Sent from my Pixel using Tapatalk
Grumblebum
Wollongong Australia
Made use of my panel door to store fishing rods with some clips made from an offcut 1" poly irrigation pipe. Each clip is 2" long and has a slit cut from it. Just cut a small section out first and test on the fishing pole and take a bit more out if you need.
View media item 87155
Used pop rivets to attached to the door.
View media item 87156
And the rods clip in nice an snug.
View media item 87157
View media item 87159
At the tip end of the rods, I added some velcro strips behind when riveting them on so they can be secured.
View media item 87158
Has worked well.
Cheers GB :beer2:
madwi
West Michigan
Been meaning to post this and finally got around to taking a pic this weekend. Storage for my car ramps, a $10 towel bar from Home Depot. They're next to the overhead door utilizing space that was kinda wasted anyway.
Good idea. :thumbup: I ended up hanging mine from a leftover piece of rubbermaid wall organizer thing. Ramps fit between the studs and keeps them out of the way a bit.
Dan in Pasadena
Pasadena, CA
My car ramps are the old fashioned stamped steel ones so kinda heavy for the towel bar idea(?) Anyone think it would still work or have a better idea for storing them up out of the way?
Kenstone1
Lotsa tools....
Nice...
I have come to build shallow/one item deep shelves now, because I hate reaching around an item to get something behind it, with that item usually getting knocked down.
All the shelves in my sheds are shallow/between the studs., so no floor space is lost.
jmo,
DRP6833
Firestone, CO
Make your own "towel bar" out of threaded iron pipe and fittings, it should hold 'em.
Thanks for all the kudus, guys and gals!
GrayFlattop
Chicago
Also had a couple of feet of wall space behind a drill press. Turned out to be unsought space for pry bars and other implements of destruction. I ended up scrapping some of my old, bent rusty crow bars so their replacements are even prettier - for now.9ba60b279a15e8fd6936fd0d59785cfa.jpg
drivesitfar
ALL: I don't know how I missed this cool thread, but I've already seen several ideas on how I CAN GET ORGANIZED.
thank you all for contributing some great ideas!!
Crazyjake8493
Upstate NY
Cheers GB :beer2:
I need to do something like that soon. All my fishing poles are in the basement in the corner and everytime I need one they're tangled together.
I hate that the garage door is such a big area of wasted space, especially since the door is rarely used. This should make good use of most of it.
flyng_fool
Frisco, TX
Yes, but do you have a VW microbus for those implements of destruction?
guyerst
Zeeland, MI
I have mine sitting vertically on a 2x4, with wheel barrow brackets to hold the tops in place. Mounted the brackets 1/2" high to give enough room to slide the ramp in place. Honestly, you could make the upper overhang out of anything (scrap wood). All the weight is on the base.
astrohip
Brenham TX
As well as the shovels and rakes!
My shovel & rake holder...
Rewind97
Mississippi
I really need to make something like that.. all mine are thrown in a corner of my shed so I can never get what I need.
I do as well. I have a corner in my shop that is just a cluttered mess with those type of yard tools. Inevitably the one you need is the one covered up by all the others!!!
Dan in Pasadena
Pasadena, CA
Looks good. Dimensionally, would they fit side-by-side on that short wall so you could use the rest of it for something else?
I wish I had a small unused wall like that. But I’ll find a place...eventually.
Unruh
Silverdale, Washington
So I’ve been looking for a way to store extension cords other than the tried and true nail on the wall and let them hang method. I found plans for a cord caddie and went with that.
First I made six of these. The dowels are spacers and are cut at 1 1/2" for my shorter cords and at 2" for my longer cords.
Here is one put together.
The arms pivot in allowing for easy removal.
Unruh
Got the shelves done! I think they turned out really nice. Overall the dimensions are 48” wide X 12” high X 13” deep.
I put in the cords and they fit!! I also added some places for my belt sanders and some other slots for whatever.
gemniii
Fulton, Ms
I've read about a third to half of this great thread and have gotten many good ideas. But I have not run across any solutions for pallet racking.
I've four "shops" totalling about 5,000 sq ft. About half of the walls are lined with pallet racking, total about 180 linear feet, ranging from 44" to 48" wide and 8' to 12' tall with from 3 to 5 shelf levels.
Half of these are set up so the first level is a comfortable working level with the first "shelf" layer being composed of either 2x4 or metal braces supporting 3/4 PT plywood with a 3/4" piece of MDF on top for a "sacrificial" work surface. Then levels above the work surface are just regular racking.
Thus, I've about 10 "worktables" which are 44" to 48" wide and 8' to 9' long. It's hard to reach the side that is up against the wall.
I've also a bunch of repurposed kitchen cabinets which I could fit on the back of the first shelf. I'd like to put the cabinets on the some sort of rollers so I could push them back against the wall, or pull them out when I need access.
Any suggestions for rollers? I'm thinking the cabinets will rarely weigh over 150lbs and "appliance rollers" will be my best bet.
Dumber than lumber
I don't know what u mean by appliance rollers. I go to Northern Tool or Hardened Fart and get furniture dollies. Remove the wheels and use them on roll-around carts, etc.
CoachR_9426
NW Arkansas
Thats a great idea. I may steal it! :thumbup:
ckucia
West Virginia
You could get some unistrut and the trolley they sell and hang the cabinets from two sections of unistrut. That would let you pull the cabinet foreward and push it back, plus you could make the bottom of the cabinet higher than the work surface below it, potentially meaning you could pull the cabinets forward without disturbing what you were working on.
Could also use the hardware for hanging pocket doors, but I would think the unistrut and trolly would be a bit more durable.
