Stillgottimefor1
I’m needing to wall-in a workshop under a house made of 8” i.d. Pipe twelve feet high. I have only a compacted caliche floor at this time, will have to pour concrete in sections myself later, but want to put up walls using the large amount of wood and tin that is already here in piles...problem is the owner will not allow me to drill into the pipe holding up the house. Welding is also a problem. So i was thinking of cutting small 2 by 4 pieces to make a square around the pipe, screw those together, and then nail my framing or girting or whatever you wanna call it onto that. Use standard barn corrugated tin on the outside and osb on the inside. The pipe is on ten ft. Centers. Small scrap shown here.
