I have been having lots of trouble cutting miters in steel 1 1/4 angle iron. I am using the Milwaukee 14" dry cut saw:
Basically, the on board clamp holds the work piece perfectly for 90 degree cuts, but for any type of miter, it doesn't hold the work solid. The blade ripped the work piece out of the clamp and launched it dangerously. The blade is trashed now.
Am I missing some bit of critical set up to make these cuts? The saw makes perfectly machined pieces when it works correctly so I want to use it for this purpose but i can't afford to replace the blade or go to the hospital.
