64coupedeluxe
Hi Guys,
I'm wanting to high lift my garage doors, actually have them follow the roof line. I'm doing this with extension spring doors.
I notice via googling today that this is usually done by adding a section of the horizontal track(that you cut off) between the vertical track and the start of the radius bend track.
I also noticed that the tracks angle out bottom to top going vertically against the door frame.
Is this angle the reason you can't just raise the tracks up and add the section you cut from the horizontal tracks to the lower section of the vertical track? As in at the very bottom.
I'm thinking yes as I installed a new door and track from craigsl!st and had raised it roughly 8" and the door binds without some shims under the track brackets. I plan to raise it higher than the 8", that was just done to see how it looked/worked.
I originally thought it could just be that the trim was installed to suit the original doors and need to replace that trim anyway.
Also is there a set minimum distance I need to keep the track from the ceiling?
Thanks.
Thanks.
