ckucia
PO of our house left a little to be desired in his installations. I'm trying to fix a few things and would like to get confirmation that I'm on the right track. We don't have code inspections here in this part of WV so I'm on my own.
Our house has underground service. The transformer is probably 200' away from the house. Meter is on the side of the house. So far so good.
From the meter, there is a 2" conduit running to a disconnect service box with 200a breaker. Aluminum wire connects them. Not sure what size, but about as large as my fingers.
So problem #1. The disconnect has space for additional load breakers. There's an opening where one presumably used to be. For whatever reason, the PO didn't use that. On the lugs off the main breaker, there is similarly large aluminum wire to the feed going to the house. And then the PO added copper wire (looks like 2awg) by opening the lugs for the house, slipping the copper on top of the aluminum wire, and tightening the lugs. This seems like a very bad idea to me and since I discovered it, I'm not using any heavy loads in the garage - just a few light bulbs when I absolutely have to. I now have a 100a breaker that fits the disconnect and plan on moving the garage feed to it this weekend. We have electric heat which makes this an even worse problem IMHO.
Problem #2. There's only one ground wire leaving the disconnect. It's aluminum, and maybe #14 (really). It's not connected to a ground rod, and I don't see a rod anywhere. I don't know where it used to go, but I know it's not doing anything now. I've never had a house with underground service, but it seems like I oughta have a ground rod here if not two and some more substantial cable running to it from the disconnect.
Problem #3. The fuse panel in the garage is right above where the water from the pumps (well and cistern) exit out of the slab and where the pressure tank is. If there was ever a problem with a hose splitting, I'd be soaked with water as I attempted to shut off the power in the fuse panel which would also be sprayed with water. This seems like a very bad idea to me.
My water line from the garage to the house isn't buried deep enough (it froze last winter when we moved in). So I'm about to dig a trench and sink a deeper line anyhow. So it seems like a good time to redo the wiring between the garage and the house. If I move the fuse panel about 8' over, it won't be close to the water anymore and will involve very little rewiring of the garage (only one circuit would be too short - the rest I can just shorten).
So my questions...
New feed to the garage will have to be about 8' longer than the existing so I need new wire. I figure 30' total for each line being generous. Would 2AWG copper be sufficient for 100amp service? Can I run 3 THHN 2AWG lines for the hots and neutral and a 4awg ground? I already have the 100a breakers on both sides and can reuse a lot of the 2" conduit.
In the garage I'm running a well pump for a 100' drilled well, and a cistern pump about 50' below grade (I think it's a 3hp). Plus I have a small compressor (hoping to get a 5hp some day), 100a welder (hoping for a larger one eventually), various power tools, etc. I'd rather over-spec the wire and not use it than underspec it and have to replace it someday.
I'm open to aluminum, but it seems like the price difference at this distance wouldn't be worth the extra PITA of the larger wire thickness.
Grounding. Do I need one or two ground rods at the house? How far from the panels and what sort of wire should I run to them? How about at the garage 9' away - does it need it's own ground rod or rods?
We have clay soil which stays damp pretty much the whole year as the house is about half way down a hill.
Should the ground and neutral be bonded at the disconnect where I'm feeding the garage and house? (They are now) How about at the panel inside the garage? (They are now).
Any other considerations I'm missing?
I'm going to bounce the whole project off my facilities manager at work to get his input, but this place is such a great resource, I figured the more minds the better...
Believe it or not, this all passed the home inspection last December prior to us buying the place.
So my questions...
