The VISES of Garage Journal
bagged89s10
CT
One the pics from EeekPay shown below. What are the marks below "M-H", looks like N KC M? If so would that be North Kansas City Missouri?
Surprised it went for $396. Looked like it was repaired.
bagged89s10
CT
My newest additions. A sweet 2” baby Prentiss watchmakers vise and a ratchet style athol 623. I was actually surprised how small the Prentiss was but it’s beautiful.
The athol spindle was either swapped or someone put the wrong spindle on the wrong vise from the factory. The 723 is the one that’s supposed to have the ratchet style handle.
bagged89s10
CT
The mother in law sent me a pic of a Charles Parker she dug out of some straw in one of their barns - looks pretty rusty and I can't tell if the static jaw is broken/welded or if it is just a clump of cow manure <:eek:
Anyone have any idea what it might be? Looks like a 3-4 incher...not sure what series had the lettering in an arc. I won't be able to grab it for a few more months.
Looks like my Parker 49.
rusty65
Pekin,IL
Actually bagged Athol at one point stopped producing the ratchet handle model and made it a add on to there other regular models of vises ie the 623. Hope that makes sense. And nice find on the baby prentiss.
Fierljeppen
Your Athol vise is a late model 623RH. For whatever reason, Athol changed the 700 series model # to a 600 series # sometime in the 1950's.
I knew this would confuse someone with your vise who didn't have the newer catalog information.
Very nice vises!
bagged89s10
CT
Very nice vises!
Nice. Athol ads are hard to find. That clears up the confusion.
honza.vosalik
Missouri
This is 2 hours away from me, 4" Columbian. The guy is asking $95. Wish it was closer.
kenc184
Nor Cal
I believe you are absolutely correct! I dropped you some old catalog scans and some other member photos of their Morgan 138 vises with different castings. The 1963 scan is the first listing of the no-38 stationary model, everything before was only offered as a no-138 swivel model.
Very nice vise and probably getting added to my bucket list.
And thank you too Fierljeppen!
RedVise
Gulf Coast, Fl
W in a circle logo on USA vise ? Any ideas ?
Brian
Techna
I don’t want this badly enough to pay the sellers asking price of 150.00, but it’s hard to look away from. It’s in such beautiful condition that it’d almost be a shame to clean it up in any way....
gman007
West Michigan
Bought today a Columbian 144M - ok deal for $25, looks like a nice heavy-duty mechanics/machinist vise, I was looking for one for a while. Always wanted one with a really big handle - you know what they say about big handles :)
Spent some time cleaning, and found something worrisome - a pertty big crack on the dynamic jaw under the jaw face. :(
I was thinking that I can probably grind and weld it, but then it occurred to me that it might be the kind of iron that doesn't take to welding well. Can anyone give me some info? Is this vise borked and is now light-duty only until it breaks, or can it be fixed? Am I possibly making a mountain out of a molehill?
Dungeon
It ***** that there is a crack. Stating the obvious, a repaired vise is rarely (if ever) as strong as an undamaged one. In any case one of the supposed better ways to repair cracked cast iron vises is brazing.
Even assuming you know how to braze (as honestly personally I am not sure if this vise is worth the expense of a profession braze job) in trying to grind and then patch the face of the jaw where the crack is and then grinding it flat all the way back to the face so that inserts fit properly will remove most of the braze material and might not add much additional support.
I suppose you could braze area under the jaw as well as the back of the jaw to provide some additional support.
Or you could conceivably go Frankenstein and drill and tap under and the back of the jaw and use bracing plates across the crack both under and back of the jaw. Or may be drill a thin hole across the width of the jaw and use a long bolt/nut to hold the two sides of the jaw together. All of which might also end up in fact weakening the structural integrity.
If this was my vise I would use as is but use it gently and look for another vise of same or better quality. There are still plenty of basic US made mechanics vises at reasonable prices out there. Or even with some luck you might be able to find a nice machinist vise for a good price.
I would also recommend while searching to look for covered screw types (not exposed screw like this one) which are generally more heavy duty.
Best of luck
MayerMR
Dallas, Texas
It is on eBay? If so, is there a Make an Offer option? I had the exact same feeling about this one that you do about that one, but the seller was asking $120. I made and offer and after some back and forth I think we settled on either $85-90? Still high for such a little vise, but I liked the looks and it looks nearly mint. Btw, it's surprisingly heavy for such a little vise at nearly 26.5lbs.
gman007
West Michigan
Techna
While this is a nice vise in its own right, it is not one of the Craftsman 519X series which are highly sought after. Therefore some (including myself) would consider $150 as being too high.
honza.vosalik
Missouri
Techna
I passed on one that wasn't as nice for $25, it just didn't work with my schedule. I agree $150 is way too much, you can actually have a 05195 from eBay for that price.
MayerMR
Dallas, Texas
Techna
You're both totally and completely right...but I just loved that airplane nose cone-esque main screw spindle and art deco design.
dungeoncrawler
Dungeon
Best of luck
Gman,
Thank you for the lengthy reply! Sad to hear that it's the worse case and not much can be done once a crack develops in a stressed area.
Could you go more into reason welding is generally avoided? I am an amateur when it comes to welding, and having watched a number of videos of people welding together vises and anvils from railroad rails, I got wondering if maybe welding isn't as out of the question.as I thought.
I am in agreement regarding any other forms of bracing - it's just as likely to weaken it at best leaving you where you started, plus the work involved.
Barring repairs, the plan was is to keep it light duty and look for another as you suggested. In any event, I am only $25 out for it, and it is still usable, so not much loss there.
And thank you for the tip about the different screw type! Do you have an example of one? I have only ever seen the jaws that are screwed at the face or pinned. The screws on this one were so bad I had to hammer them out with an impact because the faces were completely chewed up. But then the vise looks to be a better part of the century old with a lot of use, so that follows.
893cv
Cincinnati Area
My coach maker vise arrived yesterday. Way too much paint but it is complete and useable!
MissileBear
Western NY
The issue is with the metal used in vises - it's a cast ductile steel/cast iron, which is very difficult to weld correctly. You usually have to v-notch the cracked area, extensively pre-clean the areas to be welded, pre-heat the piece, weld with a NI rod (if memory serves me correct) and then let it cool very slowly by burying the piece in sand or something similar. When I was in school, I failed many times trying to get it right, and usually the metal was weakened and broke near the welds if the weld held at all. Brazing is a much better option for cast metals, but even this is not nearly as strong and is likely to break in a high stress area over time.
Railroad rails are a different metal entirely. They are usually an extruded steel alloy (perlite maybe?). It's a very hard steel designed to resist wear (as opposed to much softer cast metals) and is also much easier to weld.
dungeoncrawler
The issue is with the metal used in vises - it's a cast ductile steel/cast iron, both of which are very difficult to weld correctly. You usually have to v-notch the cracked area, extensively pre-clean the areas to be welded, pre-heat the piece, weld with a NI rod (if memory serves me correct) and then let it cool very slowly by burying the piece in sand or something similar. When I was in school, I failed many times trying to get it right, and usually the metal was weakened and broke near the welds if the weld held at all. Brazing is a much better option for cast metals, but even this is not nearly as strong and is likely to break in a high stress area over time.
Railroad rails are a different metal entirely. They are usually an extruded steel alloy (perlite maybe?) and is very hard but much easier to weld.
MissileBear,
Oof, that sounds like it's well beyond my skill or being worth of the labor and time invested. 'Tis a shame, so I'll go with using it within reason and if it breaks eventually - it will have done so having been extensively used.
Thanks for the info about the different iron/steel types! That brings me to another question (thanks again for being helpful and patient with my novice bumbling!) - how would a crack like that form? The ductile nature of the material would generally prevent this, correct?
I am assuming misuse - clamping something on one side of the jaws and either over-torquing or hammering on it, neither of which should be done with a vise.
MissileBear
Western NY
Misuse of some type....throwing a cheater bar on the handle, a blow with a hammer, twisting the work piece in the jaws, pressing bearings....I've seen a vise break from being dropped on concrete.
It's not that hard to break a vise if you abuse it. If you use it as intended, it will last many lifetimes.
The metal isn't ductile steel alone - it's an cast alloy that's a bit stronger than straight cast iron alone because of additives in the mix. It's still brittle, which is why it cracks and breaks off in chunks rather than stretching. Each manufacturer had their own recipe.
I am no metallurgist...maybe somebody can chime in on metal composition used for castings.
gman007
West Michigan
Gman,
Dungeon
MissileBear already addressed your question (and I must add, much better than I could or know about the subject matter) regarding welding vs brazing.
As for the screw, the recommendation was not per se about the "type" but rather it is about the fact that the vises whose screw is enclosed in the slide bar, generally tend to be a lot heavier and beefier than the exposed screw vises. I have attached two examples of two basic Columbian Mechanics vises (photo 1 and 2 are of an exposed screw vise and photos 3, and 4 of none exposed screw).
By the way there are few very interesting hefty exposed screw vises that are exception to this general rule. I have attached a photo of an exposed screw Vanderman 3 (photo 5) which has 6" wide jaws and weighs 162 lb!
honza.vosalik
Missouri
Ok, teach me...what is coach maker vise for? Why are the jaws so tall? I saw a Morgan 138 on FB the other day.
gman007
West Michigan
The name itself implies what they were historically used for, namely for making parts for coaches/carriage. In general they are great for woodworking.
The tall jaws allows clamping large pieces of wood to hold but with not so much pressure as to mar the wood. Quiet often the jaws are also smooth for the same reason.
RBarnes
Texas
Can we see a couple more pics of your 436A? I have a 433 1/2A. It has the later style square jaws and I'm pretty sure the swivel lockdown bolt is original and it doesn't have a wrench. Seems like i've seen several of the later Parker's with the lower profile hex head lockdown and no wrench. Something else to cross reference, in what way is your swivel base attached to the main body of the vise? Shoulder bolt or cast in peg with washer and c-clip?
You asked for photos so I stayed up till 4 am last night cleaning and mounting the vise. Not one of the monster vises most people on here seem to be looking for, but I wanted one to use that had the pipe jaws. I really appreciate the old paint and at some point will probably do something with the bright shiny screws that hold the pipe jaws to keep with the vintage look.
davethorik
Norka, Ohio
That's a nice looking vise. I like the stand, too. :thumbup:
The slides are typically longer, allowing a larger piece as well compared to a similar sized machinist vise. the jaws are thinner and tapered to clear tools shaping the part held. These are also known as pattern makers vises as in patterns for casting.
454ragtop
Carver, MA
I dunno, have a 436 myself, I'd put it in the monster class. While it's no 8 incher, it towers over most any other vise. Nice looking vise and stand.
dungeoncrawler
Gotcha, that follows my limited knowledge on the matter, glad I wasn't completely off into left field. Is that still the case with modern vise materials, or just primarily applies to vintage stuff?
dungeoncrawler
Dungeon
Ah, I gotcha! I had a moment, and thought you were talking about the screws that hold the jaw faces on, not the main screw that moves the jaw. Yeah, the Columbian I have is pretty skinny and relatively light for the size. Not necessarily a bad thing!
Does anyone know the rough vintage or have access to the catalogs this model appeared in? I tried finding it but my search yielded nothing.
MissileBear
Western NY
I saw that vise on Ebay....Oxford, PA right?
bagged89s10
CT
That vise is awesome. I think Parker’s are one of the best vises out there.
MayerMR
Dallas, Texas
Next task, find and acquire even better looking sibling :beer:
it's on the list for sure. In fact, I've got a another Reed 1C coming in. I'd be interested in trading one of them off for the right 519X swivel model if anyone has any interest. The one I'd want to trade is this one if anyone has any interest. Pretty sure this one has basically never been used.:
Dungeon
I think Merrill and Reed made some beasties with exposed screws as well. I've been passively looking for one for awhile, just because they are kinda cool - the "opposite" of what most people consider to be desirable in a vise because of the exposed screw generally meaning lower-end, or weaker, etc. *shrug*
Looks great. If those screws/bolts are zinc-plated, just drop them in a container of vinegar overnight. It'll take the zinc plating off. Then you can leave them out without rinsing the vinegar and they'll flash rust. I then apply vinegar and let it dry, rotate and repeat, until I get the desired "patina" to match the piece I'm using them on, and then wipe them down with some paste wax to seal them from further rust before putting them to use. That way they don't stick out too badly.
Stuart in MN
Minneapolis
There's a baby bullet Wilton on the Minneapolis Craigslist. They're asking $500 for it :eek: but I thought I'd post the photos here for future reference - it does appear to be in excellent original condition.
893cv
Cincinnati Area
I will be using it to hold sheet metal parts that I am forming, the smooth jaws will be good for holding things that would be marked by the cross hatching found on a machinest or mechanics vise. I've been looking for one for a few years and this one was close and fairly priced.
I will dress the hacksaw damage on the sides and top of the jaws, redo the one ball end of the handle and give it a correct paint job, then put it to work!
RBarnes
Texas
Yes, it was on ebay. I have been looking for this type Chas Parker for quite a while so I sold 3 vises too cheap to get the $$$ to buy it. Probably paid too much ( Please do not even ask the cost - I do not want the barrage of everyone telling me I am crazy), but that is what I do when I want something. Even traveled from Texas to Pennsylvania to pick it up, so it was even more expensive when you figure that in. I just could not pass up the vintage old look it had.
trijeff
Northern Cali
RB, that's almost how I feel about the sweet Reed 1C Mayer posted above ... the vise pangs be particularly strong at times me finds
Sent from my SM-G900T using Tapatalk
