First time posting here and I have searched a little for ideas. Currently I have a 30' x 70' shop that is heated with floor radiant (hot water/PEX in the concrete floor slab). Hot water is provided by an outdoor wood furnace that also heats my home and domestic hot water. My need to use the shop are now minimal and it takes a good bit of wood just to knock the chill off the entire shop. I will be draining the system in the floor to prevent freezing but wish to use the shop on occasion. I was thinking of utilizing an old HVAC unit that I have on hand as a water to air heat exchanger so that I can quickly heat with forced air on demand. I would simply hang a double row of tarp from the ceiling across the width of the shop, isolating area of about 30' x 20' to heat. This should work fine and heat the area quickly when needed. My concern is freezing of the HVAC unit when not in use. I was thinking of well insulating the unit and placing a small electric heat source within the enclosure to keep it above freezing. Any ideas about what components of the old HVAC unit to use and setting up controls would be appreciated.
