Anyone know the approx weight of a Reed 1C? I have a potential lead on a complete one in decent shape.
I would think with one of the ends of the handle on the ground the weight would be off by a bit. Try centering and balancing the handle.45.8lbs!
Reed listed the weight on the 1C with cast in jaws at 54lbs. Not sure if the stated weight changed much on the later models like ours with flattened meatball and removable jaws.
Stephen: that’s a fairly common old columbian so you might put a post in the vide parts thread in general tools asking for jaws. Are the threads for the jaws still in good shape? Another option is to make a new pair of jaws out of wood, hard plastic or soft metals like aluminum or brass.
Welcome to GJ too!
You could always make some....A guy with a welder is up to the challenge. At least get you by until you need or find something better. Ed.
Am I doing this right? Posting my vise repair question like this I mean?
I found a very cheap Columbian 504 non swivel vise. I thought it was in pretty good used shape except... it was missing the jaws. I'll try to post a couple of pictures... they are (I think called) U mount?
The jaws are 4". 1.25" top to bottom, and the raised part in the middle is .125" high and .625 wide. Hole spacing is 2.5" on center.
So... What options do I have? I found some 'Milwaukee' U mount jaws at McMaster for $72... a little pricey for me at the moment, and the listing did not give any real measurements (although I'm sure I could call and speak to someone).
I'm not attempting to restore this to original, so... I thought about brazing the 'recesses' up to the level of the middle part, and then finding some more affordable jaws and simply mount them in the middle. Any reason not to do that?
I have TIG and MIG, and an oxy torch, however I do not have a mill.
Other options?
Thank you in advance for your input!
Steve
Yeah... I might have to do that. I was hoping for hardened real (cross hatched) jaws, and I might have to make due.
I started in on the spray bombed Morgan 160 I picked up a couple weeks ago. I tried the oven cleaner followed by the pressure washer. I was surprised to see what looks like the original blue under all the dark blue. The vise was also black at some point as well. I am kind of liking the look that it has. Am I crazy? Any suggestions on how to preserve this look? BLO? Can it be dried with a heat gun? It's far too cold to sun cure it in the PNW.
I think it looks cool too.
Set it up on blocks to get any area where you stripped the paint secured from touching anything (and sticking to it) while it dries. Give the oven cleaner a few days to dry up. Then, as you already mentioned, lightly coat the whole thing in BLO and let it dry for a couple more days. It drives really hard and will bring out that cool splotchy color pattern even more. Here is my Paramo and Reed before and after cleaning and BLO:
Mayer,
All of the oven cleaner is gone and everything is bone dry. I have heard others on here saying they used a smoker or an oven to dry the BLO. I will try the heat gun. Or will it dry at room temperature?
No need to speed it along really. It's got chemical driers in it that well let it set up and dry in about a day or so, depending on the temp and humidity. There is no harm in putting a finger on it and seeing it's it still tacky. When it's not tacky anymore then you're good go to. Just remember, a light coat or two will dry a lot faster than a single heavy coat.
That said, in the summer time when it's warm out I will wipe the items down with BLO and then sit them out in the sun. That will reduce the drying time significantly, but it's really not necessary.
Ok, I'm going to give it a shot! Do you put it on the slide and all the parts? Or just the areas where you want to preserve the patina?
I now enter hour four of trying to free the cadet base from its welded prison!
MR. W: had 2 or 3 coats wiped on with a rag. since the rags can self combust and start a fire if you don't dispose of them properly or hang them to dry
The welds are extreemly hard metal. I dont know what they used but I tried a milling bit to get into the "corners" by the mounting eyes and it just chatters on top. I got as close as possible with the angle grinder and I am trying to be more precise with the dremmel. Its very slow going. I dont want to crack this base.
Consider going in from the bottom with the angle grinder. Lots of dust and sparks but you'll be getting right at all your problem points directly.
That moment when you start to see smoke coming from the inside of your grinder cut. Its finally free and unbroken! It was almost not worth all the burns, metal slivers, and temptation to wedge a chisel under it......almost!
