How would you re-enforce this door/lock?
snickers muncher
Northeast GA
How would you guys go about re-enforcing this door. I built it a while ago using 3/4 ply doubled on the edges and a few strips across. I'm finally getting around to painting and re-enforcing it. On the inside door frame I figured I could just screw some flat bar or strapping to keep the door frame from splintering, but don't know what to do for the front of the door itself. I figure those are the two weakest points. I just want to make it harder to kick in. Any and all suggestions welcome.
Thanks,
John
kd3pc
Northern Neck
the door and the frame are only as strong as the wood behind it. While door is ply and will spring pretty hard before it cracks/splinters, the frame will likely not hold up as well.
again screwing something to the existing wood is only as good as the fasteners. If you insist on fasteners, I would slather epoxy between the wood and the backing strap, then fasten it. I would do the whole perimeter of the door.
The lock set then becomes the weak link, and a plate on the door and the frame, both U shaped that straddles the door and the adjacent frame. May help.
matt_i
SE Michigan
Typical fail I worry about is a hammer smash right on the deadbolt or door handle itself.
Its possible the door splinters right there and the locksets just fall out and its over. Stronger door needed.
If they hold, the backside of the frame is also weak. The bolts, even though engaged in the strikers, just cut a slot out of the back side of the frame.
One directional improvement is to use the super long screws in the striker plates that go thru the door frame and ideally into the king stud behing.
But, there is no improvement like backing up the rear edge of the door frame with steel, distributing the load up and down and making sure its well-attached to the framing behind.
Its sort of open loop as I don't want to test my own work :eyecrazy: but I'm pretty sure its a better reinforcement than any around in a 1 mile radius so the real idea is to cause the prospective burgle to go elsewhere.
rakane
Warren, Oregon
Get or make a very large strike plate with long screws into the studs. Then get a locket with a longer bolt. Reinforce the deadbolt with a wrap around stainless steel sleeve.
Better is to buy a steel door, then do the 12" strike plate.
Meanwhile is a 30' Grady White.
water-works
Save your building. If they want in, they will tear everything up to accomplish there goal.
The popular theory that counters this is that thieves often look for easy pickings, and even the slightest deterrent can often cause them look for an easier target.
But you're right, if he's being specifically targeted, then usually the thief already knows what you have, and is coming to get something specific.
Lucid Moments
Gainesville, Ga
For the door jamb I would find some sheet metal. The thicker the better obviously, but to be honest it probably doesn't have to huge. Form it around the wood, drill and screw through the face of it. It is a long way from perfect, but relatively simple and easy to do.
1redTA
Pace FL
kicking in doors sounds like an easy way to screw up body parts, a haligan will open a door as fast
LS6 Tommy
Northern NJ
If you have access to the inside without opening the door, a big *** piece of black pipe through two big *** sleeves mounted VERY securely to the wall/studs.
Tommy
wasfuzz
Mn
Large pair of Channel locks will defeat the locks in no time and not make any noise!
sawduststeve
Havering-Atte-Bower,London/Essex boarders, England
Hinge bolts, a London Bar style security strap and two more dead locks, one higher, one lower. That ought to do it. You have two locks, the closer together they are, the more they perform like one, the further apart, the more they act as two separate locks.
Good luck
Steve
Pate
New York
A wrap around door reinforcer and a bigger strike plate are a good start. Don Jo makes both items.
bullnerd
Jersey
Is that pic from the inside or out?
I have brackets secured to the wall and two pieces of thick wood across the inside of my basement door. I'll take a pic, too hard to explain.
Spareparts
Lansing Ks.
After many breakin's at our shop I built the door frame out of box tubing and welded hinges to it plenty solid I thought, solid door and all. Nope apparently the thiefs had acquired battery tool, cut the lockset complently out of the door along with 2 deadbolts, the fabricated door jam was unharmed. If they want in they will get in.
theoldwizard1
SE MI
Steel door and frame.
The jamb is usually the weakest point. An extra long strike plate and extra long screws (that go deep into the building frame) help. If you want real security, you need to replace both and use a COMMERCIAL grade door and frame.
The next problem is attaching the door frame to the framing of the building so that a ram does not just blow the whole thing out !
My SIL is a LEO. He is the guy with the ram on the SWAT team. The only door that he was unable to bust open with one swing was an old, solid wood, in-swing door that had a 2x4 jammed under the handle on the inside, up against another 2x4 screwed to the floor.
Drop bars/security bars are great, but typically can not be "unlocked" from the outside.
1redTA
Pace FL
^^^^ this, we built a battering ram ( steel pipe with handles and weight) to get into houses. But, a firefighter carries his tools with him/her in case the tool is needed inside the structure or to self extricate. A battering ram isn’t a very useful tool inside a structure, which is why you see pike pools, axes and haligans
Stuart in MN
Minneapolis
It comes down to how much time and effort do you think you need to put into this...sure, someone can show up with a battering ram (or a bulldozer) and if they really want to get in you're not going to stop them, but a decent lock and a strong door jamb are going to stop probably 95% of the potential burglars. If they can't get in with a quick kick or two, they'll move on and look for easier pickings.
rjn2649
Il, A little west of Chicago
Don't forget glass windows are easy access points, after that peeling back the siding.
Hell, in Chicago new "stick built: houses are basically drywall w/ vinyl siding, a sharp razor knife, your in pretty quietly, if you can fit through the studs w/o too much fuss...
bullnerd
Jersey
Here's the brackets I was talking about. This was temporary 20 yrs ago! lol! Never even painted the door! Anyway, enough of my laziness!
I left the cheap curtain on and screwed 3/4 ply to the inside and then those brackets/bars.
Obviously, they can get in if they want, but this thing is pretty solid, would not be fun to try to get through.
Easy to pop the braces out and open the door.
EDIT: there's two pics below, not sure why one didn't show, click on the link to see the outside.
snickers muncher
Northeast GA
Thanks for all the suggestions guys. I finally got to it yesterday. I missed the question earlier, but that pic is from the outside and the door opens inward.
I wound up adding angle iron to the door frame with 3" screws from two directions. For the door itself I had some fairly thick sheet metal that I epoxied over the door lock area. I then put bar stock on the front and back perimeter of the door spanning the lock area. Carriage bolts go through to make a steel, plywood, lock sandwich.
The door is on my parent's storage building. I added 2x4 barricades in brackets on the double door on the side of the building. This was all about doing a quick, inexpensive improvement to deter the casual thief. As others pointed out, a few minutes with a sledge or other tools will defeat most doors.
Thanks again
LifeLongWNYer
South of Rochester, NY
You can harden the door and frame as much as you want, but if the bad actors really want to get in, they will.
There was a gun shop near here, which went to great measures to build a solid steel door and frame, they put quite a few long, fairly large diameter, bolts through the frame, and into the wall, and they made it quite evident that the door would not be an easy way into the shop. So, the thieves didn't even touch the door when they burglarized the place, they brought a chain saw and made a new doorway, about six feet from the reinforced one.
OccupantRJ
Eastern North Carolina
A wireless driveway alert with the receiver in your bedroom is a good way to know when someone is close to your door before they even get there. A second receiver outside will alert the thieves that they are screwing up at this location if desired. My units shriek 3 times repeatedly as long as the unit is activated, and have a loud tone and a softer tone for inside.
They can be partially masked and mounted at a level to not pick up pets and such. These work for other areas as well such as fence gates, and can be placed anywhere you want to monitor something. If the thieves go for the sensor, it will be raising hell until they are able to crush it, and you can have another watching that one. They are cheap protection.
I have cameras also, but the sensors let you know BEFORE something happens. If I am in my shop with the doors closed and anyone is moving in my yard, I get notified.
Stuart in MN
Minneapolis
66cj225
NH
Eye bolts for a horizontal bar out of 1/2 or better rebar into 2 or more studs drill for padlocks or pins at least to prevent sliding it out.
