Special torque wrench?
Indy125
Northern NJ
Hello All,
I know about torque wrenches and all, but I will run into a nut that only has two parallel flats on it, so I can only use an open end wrench to tighten down. A socket won't fit over these nuts, so using a traditional torque wrench with a socket isn't an option.
Does a torque tool exist that uses an open end style? Or what else could I use?
Thanks for pointing me in the right direction!!! :beer:
coljar
Belpre, Ohio
It depends on how often you run into one. Back 30 years ago when I had my business, if I needed a special tool more than once to fix something, I bought it. I looked in my latest Snap-On and SK cat., but off hand didn't see the socket you need.
coljar
Belpre, Ohio
Yeah, I just seen it and erased that part. One of the guys that worked for me at the time would say I was always looking for a reason to buy another tool.
reptilezs
torque using the hex that is on the pivot. you wrench needs to work counter clock wise
joeswamp
Massachusetts
I'm surprised a 6-pt socket wouldn't work, the nut looks like it's a standard hex shape that's had some material removed (rather than added). I would think the flats on the 6-pt would be enough.
guy48065
Calibration Lab
Most good torque wrenches come with a manual that includes the calculations to compensate for adapters that extend beyond the head. The online calculator in post #2 is awesome.
2oolhound
BC Canada
If you have clearance and can position a crow's foot 90' on your torque wrench (so it doesn't stick out the front but is 90' up or down) your torque will remain equal. But yeah, like Joeswamp says it looks like a 6pt socket should fit and may even contact the side edges near the flat.
bwringer
Indianapolis
I think there's something sticking up through the nut when it's installed, so a socket won't fit.
Jazz1
Thunder Bay On.
Hello All,
What the heck is the nut is off?
I
Indy125
Northern NJ
Thanks everyone! This message board is THE best because of its members!
The nut is from Trek Bicycles, the rear ABP (advanced braking pivot). It holds the seat stay and chain stay together on some full suspension bicycles.
nmantas
Downriver Detroit
200 in lbs is less than 20 ft lbs so pretty low torque.....I would take a cheap 6pt socket of whatever size it is and use a grinder to carve out material till you had a two sided socket. It won't be strong but will most likely not flex with only 200 in lbs of torque.
ChrisLS8
This. Cut notches out for the sides about the height of the nut. Easy peazy
intimidator782
you could always use a weatherhead socket depending on the application. otherwise as others have said, crowsfoot would work well.
nmantas
Downriver Detroit
Get a little crazy with a few files and even sandpaper to finish it up and make sure that the nut doesn't get scratched or scarred.....keep it in the box for another 20 years and probably never use it again.
joeswamp
Massachusetts
I still don't get why a 6pt socket won't work. I searched for "trek abp nut" and found this exchange on another forum:
https://forums.mtbr.com/general-discussion/torque-tool-trek-abp-rumblefish-870719.html
Now that I'm reassembling the bike, I realized that the ABP Nut (part number W305084 seen here at this link on page 32 of the download) needs to be torqued to 200 in.-lb.
This is a "specialty nut" that is rounded on two sides & flat on two other sides.
Has anyone found a socket/tool to adapt to a torque wrench for this job? I have an email sent to Trek Service, but am not betting on a speedy reply =).
The guy then responds to himself:
A service rep at Trek emailed me back, saying that a typical 20mm socket should fit fine over this nut. I feel like a doof. Anyway, thanks to Trek for the email!
There are situations where you need to torque something with an open end wrench, but I don't think this is one of them.
