Long of the short, I shouldn't have but did, and removed the spindle since there seemed to be something causing drag. (1935 craftsman 9 inch lathe, so I'd have to have a new bearing/bushing made, or buy a bushing with the correct interior diameter and manually sand it down the exterior to fit the cast)
Well, the screw hole for the variable speed wasn't machine correctly to begin with, and the metal pressed out and caused a bump from the screw going into it.
When I was removing the spindle, I had to twist it out since it was stuck in the bronze bushing. So now the bushing(bearing) has jagged marks from me twisting the spindle to remove it. I can feel them with my finer.
I have since used oil n 1500 grit sandpaper (cheapo paper w/oil is more like 2500 grit), and I have at least smoothed the scratches/grooves, but I can still feel them. I stopped because I didn't want to sand it down causing too much play.
Think I can save the bushing? Should I keep lightly buffing till smooth? Stop here since the scratches/grooves no longer have sharp edges? Or is it necessary to buy a new one, one way or the other?
***Note this is a lathe I'm not sure how well it works, been putting a lot of cleaning and work into lately, getting it ready for the first turn. First lathe***
